Cell Phones Logo
Posted on Oct 01, 2009
Speed dial will not connect to my most used # I
Speed dial will not connect to my most used # I changed possion on speed dial an it stoll would not connect.
KX-T7630 How do I edit the system speed dial numbers on this PANASONIC phone? I cannot find anything online in the manual. I can only find the personal speed dial options for storing numbers.
There doesn't appear to be a way. Sometimes on multi-phone business systems, a technician can connect a laptop with dealer software and make changes or edits that a user can't.
If that particular number needs to be at Number 1, you would have to delete them all and reprogram them all again.
http://www.voicesonic.com/panasonic/manuals/KX-T76xx_User_Guides/KX-T7630_User_Guide.pdf
I'm not getting spark from 2 ignition coils, do these need changed?
you can try changing possion of one of them to see if it works in a other possion that would tell you if it is the coil itself or something else is going on, your OBD should give codes of what cylinders are not functioning or misfire.if problem is the same try a new coil
I need to change my password on speedtouch dialup connection
To Manually change the dial up password in Windows 2000 or Windows XP - Go to your Start, Programs or All Programs, Accessories, Communications, Network and Dial-Up Connections
- Select your speed-touch connection
- Enter your new password exactly as it was given to you in the password box
- Be sure the Save Password box is checked
- Click Dial to connect to speed-touch with your new password
- Your new password will be saved when you successfully connect to speed-touch
- Be sure to save your new password in a secure location
99 Kia Sportage 4X4 is it pretty simple to replace the front rotors for the brakes ?
I bought a used 1999 Kia Sportage in 2004 from a delar which had only 55,000 miles on it. DID NOT have any problem for about two years. The timing belt broke @ 70000 miles which is normal. The company recoment to change @60,000 miles. Two years ago I had to do a tune up and had to change one of the ignition coil. This summer I had to change the power steearing pipe line and the transmission cooling line which I did it myself which was easy. It cost me only the parts. I also had to change the front struts this summer. Because the front of the car bounces when I brake the car or when it hits pot holes. IThe radiator bursted while I was driving in the city. I contacted the Kia motors why it happened they DID NOT care to reply!!! For the last two years the car some times stolls. The workshpe changed the Mass air flow sensor. It did not do the job. Then I changed the ideal speed sensor. still it did not do any good. CAN any one know why the car stolls ?. Now I had to change the heater core. Because the hot air smells coolent. I have No complaint about all the repair I made, BUT I WILL NOT forgive the Kia Motors for NOT responding to omy complaint why the radiator bursted. IF it was on the High Way it would have been a serious case. It made a very loud noice which really scared me .
Das .
1helpful
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
4helpful
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
2answers
Jeep wrangler 2.5. Motor idles up and down,
check the throttle possioning sensor on the throttle body that can cause alot of things
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
External Speed-Dial Default Lines
You have to remove line 4 from appearing on all of your phones.
Login to your system with Feature ** config.
Go to extensions find lines configuration, and set Line004 not in service on EACH extension.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
