Question about Brother MFC-8460N Laser Printer
HELP! Brother MFC-8460 "Toner Life End" won't clear
I have a fairly new MFC-8460 that I've successfully replaced the toner unit twice.
Both times, I've used a remanufactured toner unit with no problems.
This time, I can't get the printer to recognize the new cartridge. Same supplier, cartridge looks same and no parts broken. Some say it's the toner counter that needs resetting, but I can't find anyone that has an exact key sequence to reset the counter (so I know it's reset). I can get into maint. mode, but don't have what to so from there.
The manager has even reset the drum counter to no avail. The printer remains locked until I can get two more cartidges to try.
DominoBob
Wisc
  • 4 more comments
  • DominoBob Dec 20, 2007
    Solved!
    Turns out it was a bad cartridge, replaced with another re-manufactured and works fine.
    Just have to keep extras around, I guess.
    Later,
    DominoBob
  • Anonymous Feb 23, 2008
    I have tried two new cartridges. Both leave a toner error message.
  • mrcoldsetman Feb 27, 2008
    Need to reset toner and drum to print out just a few more pages. You can tell by shaking the toner cartridge that there is plenty left for a few more prints.But I know that it would take a genius to figure how to reset these devices.
    Thanks
    Mr Cold reset
  • Anonymous Jul 21, 2008
    unable to scan when faxing.
  • markbosman Apr 22, 2009
    Toner life end...
  • Anonymous Mar 13, 2014
    My Brother MFC-9140CDN wont reset after a new cartridge is installed
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Posted on Sep 23, 2008
Replace the drum and/or toner. With the cover to the printer open (where you would access the drum/toner), press the "Clear/Back" key. Screen will say "Replace drum? 1 = Yes, 2 = No." Press "1" to replace the drum (to eliminate "replace drum" error message on computer) or enter *00 to reset "toner low" warning. Screen should say "accepted" when complete.
Posted on Nov 09, 2012
  • Kent Madsen
    Kent Madsen Oct 30, 2013
    This is the answer. Worked perfectly! Thanks
  • Steve Young
    Steve Young Jan 07, 2014
    You had the only fix. None of the others work.
Nice Procedure from GlassWorker 3. My problem was solved using procedure 5&6.
Thanks
Posted on Dec 15, 2009
I have the same problem. Exactly the same. This is my third cartridge. Previous ones worked fine. This one won't. Help!
Posted on Mar 21, 2008
Toner life end message despite new toner
. To reset the "Toner Life End" message on the Brother MFC-8460N Open door press Clear/Back key
Apr 22, 2014 | Brother MFC-8460N All-In-One Printer
Brother MFC 7820N, I am getting "Toner End Life"
I fail to see why you are covering up the toner sensor led's when you have a new cartridge fitted?
Also if you are using a recycled toner from a very well known uk shop that refills toners and ink then you may well have broken the drive gear that stirs the toner. i have seen this six times and their toners do this.
It could well be one of the pitfuls of recycled toners.
Jul 24, 2011 | Brother MFC-7820N All-In-One Laser Printer
Brother Model MFC-8460 drum reset
Open front cover. The one you use when you replace the toner, while open hit the clear button the machine will ask if is a new drum and says yes and your good to go.
Feb 15, 2011 | Brother MFC-8460N Laser Printer
I replaced the toner for MFC 7840W and I am still gettin the toner life end message, I can not print. Please help
As noted from a previous poster, this one works!
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Thanks for all your help guys.
Jan 18, 2010 | Brother MFC 7840W Printer
I REPLACE THE TONER CARTRIDGE BUT ON LCD IT DISPLAY MESSAGE TONER LIFE END,OPEN FRONT COVER AND REPLACE TONER CARTRIDGE
Is this a genuine Brother replacement cartridge, if not you may find that it is not recognised by your MFC. Also worth a try is removing and reinstalling the new cartridge ensuring all protective packaging is removed. Also remove and reinstall the Drum unit as Brother actually recommend this as part of a new toner install
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Sep 26, 2009 | Brother MFC 7420 All-In-One Laser Printer
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Change of toner
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Refill toner Brother MFC 7420
open front cover, press OPTION button, on the LCD will appear a message "NEW DRUM?" ....DO NOT RESPOND....just type on the keyboard "*00" and there will appear a message "Accepted" and use it in your pleasure.
PS. in any case i blocked with paper labels the viewing windows from transparent plastic on the toner itself....
Mr. Brother, do not try to be smarter than your customer
May 22, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8460N Laser Printer Logo
8,690 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
