Powers down after 1 sec
The monitor powers and the screen comes up for about a 1 sec and then the screen shuts down. Is there a replacement board I can swap out?
    Problem Solver:
  • 11 Answers
Yes, it's possible
Posted on Oct 01, 2009
Replaced Power board, Main Computer Board, IR Board and Function board on Emerson LF501EMF4A_DS1. TV turn on shows splash screen then tv for 1 sec, then the tv powers off to a red standby led.
PS does not just shut down unless it is defective or there is some short in another location that is telling it to shut down to prevent further damage to components. Which is it? Sure the PS you put in is good? If so, issue is with some other part of the set that you have not already replaced.
Apr 15, 2017 | Magnavox Televison & Video
Hp f2105 black screen after 2 sec on?
You've asked this question in two places. This is confusing--try to ask it in one place only.
I answered it in your other request.
Nov 20, 2011 | Rosewill R700J 17" Flat Panel LCD Monitor
I have a LG Flatron L1718S; the screen display for 2 sec and then turn Black.
If the power light remains on after it goes black, the problem is the inverter board that powers the back light behind the screen, the cause is usually bad capacitors. To fix it, the board must be replaced or attempt made to repair the inverter board.
Feb 10, 2011 | LG Flatron L1718S LCD Monitor
Computer wont boot Evo d510
Choose within this options with regards to your monitor: 1. You could replace your monitor with a new one. 2. Or you could send someone or send it to a technician to repair your monitor.
Boot Up Problem: 1. Try checking the Power Supply Unit (PSU) if it give out 12Voltz. If not you could replace it with new PSU. 2. Check the motherboard if there are some blown out Capacitors. If there is, send it to a technician to replace it. If none, replace your Processor. That is the defective. That causes the boot up problem.
On boot up screen. Of course it will not show a boot up screen because there is a problem on your monitor. And so, there is also a problem on your motherboard (Processor or Capacitor).
Hope this might help. Thanks.
Jul 12, 2010 | Compaq Evo D510 Minitower (Open Box)...
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
Jul 03, 2009 | Computers & Internet
I have an SVA LCD Model VR-17S Monitor that has a black screen
Sounds like the Backlight balance sensor circuit is shutting down the inverter supply. A weak bulb can cause this or a malfunctioning sensor circuit can cause it too. Best method to troubleshoot is to substitute good bulbs; if it still shuts down, look for a pair of small electrolytic caps on the inverter board near the bulb sockets. They may be weak.
Monitor Mike.
Jan 03, 2009 | Computers & Internet
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Elo 17" LCD Touch screen ET1725L Powers off after 1 second
Your problem lies ion either your back light inverter or in the backlight tubes ( bulbs) which are embedded in the LCD display. The display has 4 ccf tubes inside of it that provide the backlighting. if any of these tubes are bad the backlight inverter will shut off after about 1 second. Because there are 4 of these tubes inside the screen you may not notice ( brightness wise) if 1 of them is out.
You can buy another backlight inverter( about $70.00 US) however, from my experience that would be a waste of money. Unfortunately, I think your problem probably lies in your LCD and the backlight tubes are not replaceable.
Hope this helps all who have this problem.
Good luck
Jim
Oct 28, 2008 | Elo 17' LCD MONITOR, TOUCHSCREEN, 1280 X...
Monitor problem
You are experiencing an inverter board failure. You will need to replace or repair the inverter. The inverter drives the CCFL lamps that illuminate the screen if the lamps draw to much current or components on the board are overheating it will shut down the backlights. Some monitors have cold solder joints on the toroidal coils of the inverter that causes this problem, very typical with HP monitors, If you are handy with a solder iron you may try just re-soldering board and replacing push-pull transistors for a few more years of use. Provide make and model and I can be more specific about probable cause and solution.
Jan 18, 2008 | AOC LM729 17" LCD Monitor
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
