Question about Air Tools & Compressors
My compressor keeps turning on
My compressor seems to always turn on every few minutes even without use. What could be the problem? I can hear it "leaking" but do not find any place where there is air coming out.
  • 546 Answers
The compressor is triggered to come on at a minimum pressure determined by the 'regulator'.leaking air you hear is the cause check petcock @ bottom of tank.check air hose inlet connection,air compressor to tank lines.
Posted on Oct 01, 2009
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Outside unit starts but stops running in a few minutes. The rest of the a/c seems to be fine but doesn't cool
there could be quite a few problems with it. either it has something to do with the high or low safety pressure switches. Or you have a low voltage issue-not getting enough low voltage power to the coil of the contactor. how long do you wait after you turn the unit on? there is a 5 to 10 minute delay in the control board to keep the compressor from short cycling. meaning to keep the compressor from turning off then on again right away. short cycling a compressor too much will ruin it. There also could be an issue with the delay board it self. Or its a heat pump it could be an issue with the defrost board or the defrost sensor. I have even seen it to have a short in the wires of the coil of the contactor. But when that happens it will burn out the transformer or the low voltage fuse of the transformer or on the control board.
have you got it figured out already? If not can you give me more info on what it does? Or if it ever comes on after you wait at least ten minutes. Can you hear the hum the coil of the contactor makes when it is calling for the cooling. you might even have a problem with the contacts of the contactor not getting the proper power thru it to turn or keep the unit on.
Like I said there could be quite a few different possible issues with it to not stay on.
Apr 13, 2013 | American Standard WCZ036F Air Conditioner
COMPRESSOR RUNS A LOT
Your model has a mechanical thermostat inside the control panel. I believe you have something else going on like a bad fan, start relay, capacitor. Something is causing the compressor to struggle to keep up and in turn causing the compressor to short cycle. If the thermostat has no control over run time then something like I explained is causing the problem. Here is a parts manual=> ED5VHEXVB04 Contact me if you would like my help, Thanks Sea Breeze
Feb 26, 2013 | Whirlpool Refrigerators
My refrigerator is stuck in defrost mode
If your refrigerator is a few years old it may have an electromechanical timer to control the defrost cycle. With age and/or lots of dust the timer motor can wear out or the switch contacts can get stuck.
Behind the grill below the door there should be a small black box with several wires coming out of it. On the front of the box there is a small (dime sized) round disk with a slot in it. This is the defrost timer, a 24-hour clock mechanism which switches the cooling unit off and the defrost heaters on for 15 or 20 minutes every 24 hours (approximately). Insert a small insulated screwdriver into the slot and turn it slowly clockwise until you hear a click. The compressor and fan(s) should turn on (if they aren't running already) and the defrost heaters should turn off. If you continue turning the timer disk you should hear another click and the compressor & fans will shut off and the heaters turn on. Stop turning the disk at this point. Wait a couple of minutes and then turn the disk a few degrees farther (5 degrees represents about 20 minutes). You should hear a click and the compressor starting up again.
If there is no change and the heaters still seem to be on, then you may need to replace the timer (it should unplug from the wiring harness). A Home Appliance Parts store should be able to provide you with a compatible replacement timer.
Nov 19, 2012 | GE GSS22JFMWW Side by Side Refrigerator
I turn off unit with the remote. After a few minutes the compressor turns on without turning on the unit. The digital lights do not come on. It still shows the unit to be off. I have to press the the small...
The Relay or the Magnetic contactor is stock up so the contact has always a power. Or your Supply from the relay and magnetic never turn off. Try to tap this to release from being contact. If can be remove replace it. If the supply of the relay has power even if your turn of the unit then your problem is in the electronic control unit. Your need service personnel to do this.
Sep 25, 2011 | LG Electronic Window Air Conditioner
Can hear motor working turned up fully stillnot
Be sure what you hear is not the fan instead of the compressor. Unplug the unit, wait 10 minutes, and plug it back in. Listen for the compressor to start up, or even listen for a faint "hum and click" sound. That would be the compressor trying to start.
Jan 06, 2010 | Frigidaire FRS26ZSG
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
A/C air sometimes cold, sometimes not on VW Beetle 2001 Turbo
AC will not work with temps are cold even when it is turned on. The air is colder cause the temp is colder. The AC cycles in hot weather because the AC charge is low and needs recharging. You will know this if you open the hood run the AC and you will hear the clicking sound of the AC compressor magnetic clutch. You can recharge it easily buy buying a compatible can of refrigerant. I suggest buying the kit with the gage so you don't overcharge the system which will cause freeze ups
Jul 03, 2009 | 2001 Volkswagen Beetle
Air Tools & Compressors Logo
53 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
