Question about Kenmore Washing Machines
Hello, my Kenmore 90 series washer is shaking badly on spin cycle and we discovered the tub inside seems to be rather loose, does this mean something may have come unhinged?
    President:
  • 1,937 Answers
This assumes that you have a basic KenmoreHello, my Kenmore 90 series washer is shaking - 2.gif / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool2.gif / Kenmore installation and maintenance manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Thefirst thing that I'd do is pull the cabinet and check the levelingsprings and plate pads. These are designed to keep the tub frombouncing against the cabinet during the spin cycle.
Following is a description of how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The Sears diagram shows where the springs and pads are located.
The top load Whirlpool / Kenmore washer has a tub that is designed to somewhat "free-float" The springs and pads keep it from getting too out of control. If one or more of the springs or pads is loose or damaged, the tub can contact the cabinet making a very loud sound.
Posted on Oct 01, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
Hello. i have a kenmore washer machine 70 series that jumps all over the place when its on spin cycle and yes I did make sure the washing machine is level. I just don't understand whats happening
Hi P, I don't understand why I'm getting these questions, because I'm in the automobile section, but as I'm here and so is your question, here's the answer! The machine is being thrown out of balance. Try loading the clothing more evenly and see what happens. If the fault reappears it will be the bearings and centralization mechanism inside the spinning basket. Keep in mind that centrifugal weight is increased as the tub rotates. If all the clothes (or most are on one side) the weight increases with the speed and will make the whole machine shake. If its something which has recently started after having had the machine for some time, I would suspect a bearing or broken mounting inside the spin tub. Regards John
Feb 12, 2012 | Kenmore 24032\24036 Top Load Washer
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Washing Machines
Kenmore 90 series washer. As the tub tries to
It sounds like you have a bad timer. If you change the position of the timer and it does not change what is going on the the timer has to be bad. However I am not certain what you mean by the agitator turns all the time. Is it agitating while spinning and draining?
Apr 15, 2010 | Kenmore Washing Machines
Kenmore washer stock no. 22642 shakes terribly during spin cycle
There is a suspension plate under the tub.
It also has 3 pads on it to support the tub.
There are springs attached to support the angle of the tub.
Check all these parts and repair or replace as necessary.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Mar 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washer 70 Series shakes badly during spin after repairs
make sure that the 3 corner triangel thats betwwn the tub support and the base is in the right position all 3 parts corners should be pointing the same way
Mar 03, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
327 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
