Question about Panasonic DMR-E55 DVD Recorder
"No Read" display...99% of the times.
I get the same problem on my DMR-EZ17 but sometimes, if I keep reinserting the disk (mostly RAM) it will read and work properly. However, if I remove the disk the problem will start again. Sometimes it tells me to reformat the disk but then won't format. A week later it will accept the disk and record or play the contents. I tried a cleaning disk and got the same error..."no read". I also have a DMR-EZ55 it too occasionally does the same things. What's going on?
Ernie
OK. Since the laser cleaning disk could not be read I used a can of air (used for air brushing) and blew air into the disk opening. I thought I might clean any dust that may have collected around any parts that needed to be cleaned. This seemed to have worked. It is also possible that dust accumulated in an area that would not allow the disk to line up properly. This could explain why it worked sometimes. If this continues as a problem I will use the EZ17 only as a tuner for my EZ55.
Posted on Oct 02, 2009
Disc is in player but shows no disc and door will not open
if bthe disk doesnt read it takes awile to open up again check that the cd is the right region or compatible
Jan 06, 2011 | Panasonic DMR-EZ17 DVD Recorder
I have a Panasonic VHS-DVD player/recorder model DMR-ES35V. I was recording and playing back at the same time using a DVD-RAM disk (using the time slip feature). After about an hour of viewing I got an...
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Oct 21, 2010 | Panasonic DMR-ES35VS
My Panasonic DMR-EZ17 DVD Recorder keeps saying
You have to use the remote for this unit or a remote for a similar dvd recorder, when you have it hold the enter/ok button and the number 1 or which ever number your stuck on 2 or 3 for 5 second and then go into setup and change it to the one you want RC1 ,2 or 3 !
Jun 26, 2010 | Panasonic DMR-EZ17 DVD Recorder
Stays in self check mode
If self check keeps going after 1 minute unplug machine and open top cover remove 4 screws that hold the recorder top cover remove disk reinsert screws and plug in see what happens.
Most of the time a small scratch or fingerprint on recorded disk cause these units to lock up
Jul 18, 2008 | Panasonic DMR-E55 DVD Recorder
HELP
"To fix the problem that your having with the remote press the number 1 & enter on the remote at the same time for 7 seconds."
Apr 20, 2008 | Panasonic DMR-EZ17 DVD Recorder
No read
The DVD-RAM Disk had trouble afeter Multiple recordings or any scratches. Buy a new DVD-RAM Disk and Try using that.
Feb 19, 2008 | Panasonic DMR-E50 DVD Recorder
DVD Ram recorder
Mine, a Panasonic DMR-E80H, didn't like some of the Ram disk either. Either I was trying to erase it or just read it and it would shut it self off and go into recover mode.
So, I pulled the plug overnight. Then, first thing after I plugged it back in was to eject the disk before it tried to read it. Once the disk was out. It stopped going into recover mode.
Good Luck.
Dec 02, 2007 | Panasonic DMR-E80H DVD Recorder
No picture
[I am assuming that the recorded disc was not made using the DVD recorder]. It's most likely that the video portion of the file is encoded in a format that is not supported by the DVD recorder. The player only supports DivX, JPEG, and MP3 formats. So try transferring the file on the disc to a computer and encoding in a supported format. You can use free online services such as http://media-convert.com/ or http://www.zamzar.com/ to encode media files into different formats.
Jul 29, 2007 | Panasonic DMR-EZ17 DVD Recorder
DMR E55 won't read RAM Discs
while you was replacing the voltage regulator you damage part of the microchip computer replace it.there after your worries will be over
Mar 26, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DVD problems
sorry to say but both of these sound like loader problems.ie the optics are faulty,you have to replace the full assy called a loader assy when this happens.Panasonic are the only company who offer part exchange tru authorised dealers.ie send back the faulty one and they will give reduced price on new one,.As to other makes see a lot of sonys with optic problems as well so isint just a panasonic problem.You could also try using ordinary dvdrs instead of ram discs as the optic has to work harder when recording and playing ram disc due to information contained.Hope I helped!
May 15, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-E55 DVD Recorder Logo
181 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
