Coleman Propane Forced Air Heater w/Electronic Ignition
Problem for Coleman Propane Forced Air Heater w/Electronic Ignition...
I have a Coleman furnace, model # 7995-656, in a
By jandp1969 on Oct 01, 2009
I have a Coleman furnace, model # 7995-656, in a mobile home and the blower is short cycling. It will run through it's cycle, shutdown for a minute, and then just the blower will kick on again for 30 seconds, shutdown for a couple of minutes, and then kick on again for 30 seconds and shutdown again. It has new filters, and a new t stat. What do I need to check, or replace? Thanks
Comments:
Oct 01, 2009
- Thank you very much for the info and the quick response. I will get the switch changed out, and let you know whether or not it worked.
Oct 28, 2009
- protek 480, thank you. you were right on the mark. the part plus shipping was only $16 and a five minute change out. jim
Best Solution
posted on Oct 01, 2009
Very Helpful)
protek480
Rank: Guru
Rating: 86%, 506 votes
This is caused by the 'fan switch'. It normally holds the fan blower off until the heat builds up a bit, then it starts the blower. If the blower begins cycling, change the fan switch. It's located right on the side of the duct inside the furnace with the cover off.
This is what it looks like:
Comments:
Oct 28, 2009
- So glad to hear Jim, I'm always glad to hear back from someone happy that I helped! Doesn't it feel good to fix it yourself? Craig
Popular Solutions for Coleman Propane Forced Air
Questions and Unsolved Problems for Coleman Propane Forced Air
Do you recommend Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)?
Answer
Answer
My Coleman furnaces with electronic ignition just stopped working I think its the ignition. how do I... (More)
Answer
hi, i have a el wagon and the centeral locking ,keeps going up and down, have not found a solution... (More)
Answer
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble... (More)
Answer
evertime we lower thermostate at night then raise it in the morning the resit light is flashing then... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heaters Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
