Question about Goldstar MV-1501 Microwave Oven
Took lightbulb out to replace and microwave went dead. No power at all. is there a reset button?
    President:
  • Goldstar Master
  • 1,922 Answers
Open the cover theres a 10-15-or 20 amp ceramic special fuse in the unit, sold at most hardware stores get the right amp rating,its on the side of the fuse
Posted on Oct 05, 2009
Inside lightbulb went out
look at the top. there may be an access thingy you can remove to get to the lightbulb. replace the lightbulb with suitable replacement. problem solved.
Feb 16, 2014 | GE Microwave Ovens
The inside lightbulb went out how do we replace it?
open the microwave. If there is a removable panel on the top, remove it and replace the lightbulb.
Feb 16, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
All power went off on a condo I rent out. When the power came back on the microwave was dead. It is over the range and has power to the outlet.
Look for a reset button in the back--press and release. If no button, or it didn't help, The case must be opened--look for a blown fuse. If one is found and replaced--ok? If it still doesn't work, you will need a multimeter to verify power is getting into the equipment and getting to various sections. Was it running when the power failed? That would likely have shorted the high voltage diode in the magnetron power supply. There is also a metal fan-like device called a stirrer that is located inside the metal waveguide where the microwaves enter the cavity and it occasionally arcs through it's plastic bearing. When it does this, it shorts out the microwaves and blows a fuse. Replace the stirrer as a unit. Hope this gets you running again!
Aug 25, 2009 | Microwave Ovens
Dead Microwave
Check your plug and change the fuse there also.
You might need to rechange the 20 amp 250v fuse behind the control panel again due to the recent spark.
If none of this works then i'm afraid a certified technician needs to check the power packs and boards
May 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid Microwave went blank
Is there a reset button or something I am not aware of?
May 20, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Unit lost power
there is an internal ceramic (white) fuse in the microwave just under the cover on the right side
May 04, 2009 | Microwave Ovens
The built-in microwave went dead as I attempted to screw in a new light. It arc'ed, then there was zero power to the unit. Is there an in-line fuse or circuit-breakers?
was cooking on the stove below the microwave and had the fan on. the nicrowave went out all together and will not come back on. it did not blow a fuse in the breaker box. is there a reset button or something to turn back on
Aug 05, 2008 | Microwave Ovens
Maytag MMV4205AA - Just went dead
It is a thermal fuse Ijust don't know where it is located
Apr 15, 2008 | Maytag MMV4205 Microwave Oven
Microwave
There won't be a reset button.
Is it dead? No display, no lights, etc.?
If your outlet is live but your microwave is dead, then you likely have an open internal fuse, thermostat or thermal cutout.
Please post back if you need more help and think you or a friend want to work on it.
Nov 01, 2007 | Microwave Ovens
Goldstar MV-1501 Microwave Oven Logo
221 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
