Question about OKI C3400n Laser Printer
Oki c3400 replaced toner but amber light still on!
I replaced all toners and drum but the darn amber light still illuminates so i cannot print. where are sensors? can i override and/or trick it somehow??
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
I have and OKI C3400. My printer is showing globs
yuo have a leaky black toner cartridge
take out the cartridge and look for damage
aslo check the fuser for damge or leaks
replace any damaged cartridge
Mar 22, 2010 | OKI C3400n Laser Printer
I have just put new toner cartridges in my Oki C3400 and I am getting the message of "toner sensor error"
look this solution http://my.okidata.com/oki-faq.nsf/FAQCentral/C384D8F74A91CF6E8525765E0065F636?OpenDocument
here the solution for your problem
i hope that it's helpful .... bye
Mar 05, 2010 | OKI C3400n Laser Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
On an OKI C3400 the alarm lights blinks amber once a second. Cannot print status page. Replaced black toner and drum and re-installed other colors with no change.
THIS SOLUTION IS FOR AN OKI C3400N ONLY
As I'm sure you know, that blinking amber light indicates that:
  1. A toner lock is not fully "locked", or
  2. A toner is empty, or
  3. A drum is empty or near empty
The first question should be what does your C3400 monitor software tell you is wrong? I am assuming it said the black toner and/or drum needed to be changed - so you are fairly certain it is the black that is where the problem is? You may also have run the report from the printer that you get by pressing the "On-line" button and seen what is failing.
Assuming that is the case, and one or both of these signals an empty black toner, the problem may be in the new black toner cartridge. You can try this:
  1. Make sure the toner "lock" on all toners is fully engaged - assuming they are
  1. Open the top
  2. Lift out the entire black assemble including the toner and drum components.
  3. Keeping the assembly in the same orientation as you lifted it out, look on the RIGHT end.
  4. You should see two metal contact points, near the top at about the same level as the top of the toner.
  5. Just below these contact, you should see a small, rectangular hole - about 1/4" square.
  6. If you look in there you may see what looks like a small piece of black plastic that covers the hole from inside.
  7. If so, take a small pointed object (like a bent paper-clip) and gently reach in the hole and touch the small plastic piece on the inside that is covering the hole.
  8. You should be able to gently lift that piece of plastic UP.
  9. You may have to try lifting it a time or two, but it should stay UP if you have a new black toner installed.
  10. Once you have it UP carefully reinstall the assembly.
  11. Close the top and let the printer recycle.
  12. You may need to try this a couple of times to get the plastic to stay up on your new toner.
So you understand, here is what may be happening. That little piece of black plastic actually sits in line with a sensor in the printer that monitors toner / drum levels. When a new toner is placed in, that piece of plastic should be UP, so the sensor can monitor the level. As the toner gets used, the plastic liece gradually falls down until it completely blocks the sensor - indicating the toner is empty. That is how the monitoring software knows how to signal you.
This has worked for me several times - most especially when I tried using non-OKI OEM 'compatible" toners - but no guarantees this will help you
Jan 07, 2010 | OKI C3400n Laser Printer
Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Jan 27, 2009 | OKI C3400n Laser Printer
I have an Oki C3400 that wont print
Could very well be the sensor window. I suggest looking at the side of the drum on the right side and pushing a q tip into the opening. heres an older model thats sort of similar instructions. http://www.c3400.co.uk/index.asp?menumode=0&content=sensorerror
Also you can check the exact error code here. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Dec 10, 2008 | OKI C3400n Laser Printer
Oki c3400, Have replaced cyan toner 3 times now but still saying toner empty cyan
Check the window on the side of the drum where the sensor sits. It is on the right side of the drum and can be pushed open with a Q tip it is a small black window.
Nov 20, 2008 | OKI Office Equipment & Supplies
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
New toners and drums, but flashing amber error light - won't print now
Have you replaced the printer drums? The status monitor will tell you what percent they are at (similar to the toner cartridge status). This fixed my problem before.
Jun 07, 2008 | OKI C3400n Laser Printer
OKI C3400n Laser Printer Logo
1,059 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
