Question about Sharp Office Equipment & Supplies
Where is the toner counter? - Sharp Office Equipment & Supplies
  • Sharp Master
  • 1,297 Answers
The machine not avaible to toner counter only the copy counter.
Posted on Oct 01, 2009
No loading toner my ricoh aficio 3025
you need to replce the PCU - unit order code is
  • B205-0153
  • that depends on the counter number.
  • or the cap from the other toner is still inside the the toner holder.
  • check the old toner bottle does have a cap on it.
  • how ever for i need the print counter to see if the PCU is for replacement.
  • write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
  • please write some additional info.
  • Best Reagrds
Oct 16, 2016 | Ricoh Aficio 3025 All-In-One Laser Printer
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
Error code E03-12
Enter in the tehnical rep.mode,counter select the consumables mode and reset the waste toner counter.
Jan 23, 2012 | Panasonic Office Equipment & Supplies
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
Panasonic dp-c322, "replace black toner"
This model estimates toner usage based on dot count.
You can reset the counter by pressing "function" key, then counter view. Scroll down near the end and you will find toner counter reset. Select "k".
Feb 15, 2011 | Panasonic DP-C322 Copier
How do we "clear toner counter" from the display screen
Reset the toner counter by pressing
the LIFE key (flip up the Rapid Key overlay if necessary), the "2" key,
and the START key.
Oct 21, 2009 | Sharp FO 6600 Plain Paper Laser Fax
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
Rocoh ac104 toner reset
I believe it has a 'quick blow' fuse on the front, left side, that needs to be replaced to reset toner counter.
Apr 08, 2009 | Ricoh AC104 All-In-One Laser Printer
B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Jun 12, 2007 | OKI B8300 Laser Printer
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
