Question about Intuit QuickBooks Premier: Accountant Edition 2003 (275957) for PC
In quickbooks pro 2007, the date format is mm/dd/yyyy
I want to change it to dd/mm/yyyy. I do not know how to do this, I do not know how it was changed to what it is now.
Hi, i am using windows 7 and clicked on start, control panel, regional and language, and then found my settings (was having same problem with quickbooks premier and the date set to US) and found i had accidently selected in the install of windows 7 [English-USA] instead of [English-Australia]. i altered two settings and now my quickbooks is working fine. whenever i searched for this on quicken help sites it did not indicate clearly how easy it was to fix this.
Posted on Oct 26, 2010
I cannot put my bday in and it turns blue
Have you tried all formats of date?
dd/mm/yyyy
mm/dd/yyyy
yyyy/dd/mm
and so on......
Sep 02, 2015 | HP Computers & Internet
I want to know when on my mobile phone it asks my date of birth and when entered says it wrong i think i should know when i was born
It seems like you are not entering it in th right format like:
DD/MM/YYYY which mean two digits for the two for the month and for the year 01/01/2015 now this is just one example there many different formats like yyyy/mm/dd mm/dd/yyyy mm.dd.yyyyy and so on
Mar 11, 2015 | Cell Phones
My Nokia E5 is set by default to daylight saving mode, but it is canceled this year in Egypt, so I need to uncheck the auto adjust daylight saving but I cannot.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select OFF, the phone will NOT
automatically update the date and time.
May 22, 2011 | Nokia E5 Cell Phone
I'm not understanding how to change the date in the date worksheet on the BAII. When I enter the numbers and (enter), I get and error 6. Any suggestions on what I'm doing wrong?
Error 6 indicated an invalid date, such as a month greater than 12 or a day greater than 31.
The calculator has two different formats for dates: DD-MM-YYYY and MM-DD-YYYY. To see the current format, press 2nd [FORMAT] down-arrow down-arrow. To change the format, press 2nd [SET]. Press 2nd [QUIT] to exit.
Jan 19, 2011 | Texas Instruments BA II PLUS Financial...
My LG KS360 phone has developed a date fault since 1 Jan 2011 whereby it is saying 32/83/2010. I cannot fix it. Please advise.
Noticed the same problem today. The "set date" option wouldn't let me reset the day, month or year to anything sensible. Changed the date format to MM/DD/YYYY (it was previously DD/MM/YYYY). Then it let me set correct month, day and year. Reset the date format back to DD/MM/YYYY and it's still correct (and will now let me change it while in this format). Don't understand it, but seems to have fixed the problem. (Guessing it was something to do with 2009 changing to 2010??). worked for 2011 also.
Jan 02, 2011 | Cell Phones
My Nokia N-70-1 has the wrong date, I tried to correct it. But it won't go past the twelth of the month and its well past the twelth. I need to get the correct date please help!!!
it looks like you are trying to put the days in as months, there is a good chance that the date format is wrong, you can change from dd/mm/yyyy but it looks like it is set to mm/dd/yyyy, go into settings/date and time/date format and change accordingly. good luck
Aug 21, 2009 | Lands Phones
How do you set the date on an LG KS360
http://www.o2.co.uk/deviceinfo/device-pdfs/lgks360eng.pdf
Manual
Hope it helps.
Most cell phones get the info from the provider based on your triangulation.
It is in the Settings Menu.
Under DATE & TIME
More detailed Instructions....
Changing your date & time
You can set functions relating to the date
and time.
list below:
Auto update - Select On, the phone will
Jan 03, 2009 | Cell Phones
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Date format in quickbooks 7.4
If it's anything like Excel, someplace in the FORMAT menu should be options to allow you to change the date format. (Block off the cells, row, or column in question, click FORMAT in your toolbar.) You may have different country options or formatting choices within the date type.
Nov 15, 2007 | Intuit QuickBooks Premier: Accountant...
Intuit QuickBooks Premier: Accountant Edition 2003 (275957) for PC Logo
172 people viewed this question
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
