Question about Mackie SWA1501 Subwoofer
Any idea why my Mackie swa1501 bass bin has blown 2 speakers in the last 3 months? Bass Drum is the heaviest instrument going through it, but I never let it clip, I also run a fan on it which keeps it cool. I'm using it with a srm450 and on the other side a swa1501 with an older mackie bass bin.mmmm getting expensive!
    Problem Solver:
  • 5 Answers
Does your swa1501 get hot just being switched on ?
sounds like your output transistors breaking down or your dc to dc rectifier is shorting this would dumping high voltage to the speaker. I guess your speaker coil is burnt . check Q4,Q5,Q7,Q12.Q14,Q15,Q17 and Q18 these are all mosfet transistors that commonly break down..
Posted on Oct 11, 2009
  • Chickenwatt Sep 14, 2010
    You have to check 2 things
    1- power supply switch that is one irf640 and two irf630, also check 330 ohm resistors and
    zeners aside the big caps
    2- Output transistors that you can meausre in circuit in diode measurement, the two drivers MJE15032 and MJE15033 each one should measure 58 ohm between base and emiter and also check the diodes near the emiter resistors which are 3.3 volts
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Jan 28, 2014 | Mackie TH-15A Active DJ Powered THUMP...
One speaker stopped playing bass
Sound like either the crossover or the driver has blown or, if you're lucky there is a loose connection internally if you have only checked external connections.
Jun 01, 2013 | Mackie MR5 MR5 Reference Monitor
One of my MR8's has only its tweeter working, im guessing the bass driver might be blown? How can i test this though and be sure it is the bass driver and not just a simple electrical fault?
Open the unit and remove one wire from one of the woofer terminals and using an ohmmeter check the resistance between the terminals. It probably should be between 6 and 16 ohms... they don't give the specs on the speaker... if it is very high or infinite resistance, the voice coil is blown and you be re-coning or buying new speaker. These are close in speakers and intended for a small room for studio listening while mixing. If the speaker is OK, then the bass amp in the cabinet has a failure... pray, as that is cheaper to repair than a speaker.
Sep 22, 2011 | Mackie MR8 150W 8 Active Two-Way Studio...
I have a rumble 100 bass amp which used to work fine until now! I've had it about 2 months and have only played it about a dozen times. Today, while practicing with a new band, 90% of volume got lost. Now...
It unfortunately sounds like a blown speaker. Try getting at the speaker and gently moving the cone with your fingers. If you feel a rubbing sensation you will most likely have to consider a new speaker. Make sure you get one with the same impedance (ohms) and the same or better power handling.
Jul 07, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Mackie SWA1501 Base Bin - Circuit Boards burnt.
They are not publicly available. Mackie authorized service centers are the only places that will have that information. The amp (if it has failed) requires a bit of skill to rebuild, and up to 100$ in parts alone. (not including the speaker driver if it's blown). I have repaired several of these in the past, and they aren't that simple. There is also a service bulletin about 2 diodes that usually need to be swapped with one another because of a defect during manufacture (the parts were installed incorrectly). (One is D20) if you rebuild the amp, and fail to address the diodes, it will fail again very shortly.
Jun 12, 2009 | Mackie SWA1501 Subwoofer
Mackie srm450 the tops on one speaker is not working
Hi There, This is quite a common problem with the Mackie SRM450's. You will find that you need to replace the diaphram on the top. This can be done by removing the 16 screws from the back of the Mackie (quite a long pain in the **** job) with a long handled cross head screw driver.
Once you have done this you should then remove the hex bolts from the back of the drive where the black and right terminals are. When this is done, pull off the cover and swap the diaphram out. With the new diaphram in place reverse the steps above but before you screw the back on, power it up carefully and check the sound is now working.
If the diaphram keeps going eg every 3 to 4 months then you will need to change the driver which is quite expensive to do. If you need spares and are based in the UK, contact LondonSpeakerShop.com who carry spare parts or can undertake the repair.
Hope this helps.
Feb 22, 2009 | Mackie SWA1501 Subwoofer
Bass pops
Hi There, Have you checked the 3 fuses that clip onto the main amp board? You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these with a new fuse and hey presto you should have eradicated the popping. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Hope this helps. Grant (from www.LondonSpeakerHire.com)
Feb 01, 2009 | Mackie SWA1501 Subwoofer
I have a pair of mackie srm 450 and one swa 1501 the bass output in one of the 450s has no sound. i hear sound only from the high frequency part of the speaker
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Dec 04, 2008 | Mackie SWA1501 Subwoofer
Round bass
get a bass amplifier and connect to the subwoofer.
Apr 14, 2008 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
669 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
