Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Problems with Zune and Driver Installation
Ever time i plug my zune into my computer, i get prompted for driver installation, i will install, and it will install, say it was complete, i will then proceed to disconnect and reconnect the zune, only to get re prompted (My OS is Windows Vista 64 Bit)
Open my ipod always hang up
Posted on Oct 01, 2009
8 gb zune does not take a charge or turn on.
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | zune.net
Device Driver Failed
You need to have windows media 11 installed. Can you try the player in another computer to see if it works there?
By the way is your vista updated to sp1?
www.windowsupdate.com
Jul 17, 2008 | Samsung Yepp YP-P2 Digital Media Player
Zune software won't recognize Zune when plugged in
Go to Device Manager by right-clicking on My Computer > Properties. Depending on what version of Windows you are using you will see Device Manager somewhere (might have to switch tabs).
With your Zune plugged in, you should see it under Portable Devices or Disk Drives or something similar (look under anything that could describe the Zune).
Next there are a few things you can try:
1) If the Zune is not installed (has a yellow ! next to it), right click and update driver, then tell it you want to specify where to look, and look in Program Files\Zune\Drivers\Zune\ . The file Zune.inf should be in there, that's the Zune driver.
2) If the Zune is installed, right click and select uninstall, then reinstall the driver I specified in step 1.
That should work, if it doesn't right click on the Zune in Device Manager, go to Properties and tell us if there are any error codes or if it says the device is working properly.
Jul 16, 2009 | Sony PlayStation Portable (PSP) Console
I dont have a installation disk and the new hardware cant pick up anything to install it
Check the link below and download the driver for free:
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Microsoft-MP3-Zune-Digital-Media-Player-Driver-14.shtml
Hope this helps and have a great day!
Jul 13, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Usb device not recognized when i plug in my zune
do you have the software installed? or a older version installed? if so that could be your problem with the drivers. try downloading the zune 3.0 software directly from the zune website instead of updating ,  here is the link to the download page
http://www.zune.net/en-us/software/download/default.htm
Make sure you uninstall any previous zune software first!
Hope this Helps
A+Support
Apr 10, 2009 | Microsoft Zune JS8-00001 Digital Media...
My 4 gb Zune was charging and now it wont come back on!
I found this on the Zune technical support (if this does help, be sure to rate my solution please):
Your Zune device is not detected by your computer or the Zune software
View products that this article applies to.
SYMPTOMS
When you try to use Zune Software, you experience one or more of the following symptoms:
• The Zune device is not detected by the computer.
• The Zune device is not detected by Zune Software. In this case, when you pause on the device icon in the lower-left corner, you receive the following error message:
No Zune device connected
• If you restored the Zune device software, the following messages are displayed on the Zune device:
Connect Zune to your PC
On your PC, open the Zune software and restore the Zune device firmware
THINGS TO TRY
To resolve this issue, follow these steps:1. Update the Zune software on the computer. To do this, click settings, click software, click GENERAL, and then click CHECK FOR UPDATES.
If the issue is still not resolved, go to the next step.
2. Restart the Zune device.
To do this, follow these steps: a. Set the Hold switch to the unlocked position.
b. Press and hold the Back button as you press the top of the Zune pad.
When the Zune device begins to restart, release the buttons.
3. Disconnect the Zune device from the computer, restart the computer, and then reconnect the Zune device.
4. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
5. When you connect the Zune Sync Cable to the connector port of the Zune device, make sure that both ends of the sync cable click into position. Additionally, make sure that the sync cable is not connected to the device at an angle.
6. Connect only one Zune device at a time. If you already have a Zune device connected to the computer, any other Zune that you try to connect will not be detected by the Zune software. Disconnect any additional Zune devices, and then try to connect again.
7. If a full-screen battery image appears when you connect the device to the computer, you must let the device charge for several minutes before the device will start and be detected by the computer.
For more information about how to charge a Zune device, click the following article number to view the article in the Microsoft Knowledge Base:
927348 (http://support.microsoft.com/kb/927348/) How to charge the battery in your Zune device
8. If you are using Windows Vista, install the Cumulative update rollup for USB core components in Windows Vista software update. This update resolves some reliability issues in the USB core components in Windows Vista. You will achieve better reliability in various scenarios by installing this update.
For more information about this update, click the following article number to view the article in the Microsoft Knowledge Base:
941600 (http://support.microsoft.com/kb/941600/) Cumulative update rollup for USB core components in Windows Vista
If you are not using Windows Vista, or if the issue is still not resolved, go to the next step.
9. Examine Windows Device Manager. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
b. Click Device Manager. Zune should be listed under Portable Devices.
Note If the device was installed incorrectly, Zune may be listed together with a yellow exclamation mark (!). Or, it may be listed under Other devices as USB Device.
Double-click Zune, and then click the Driver tab. The current version of the driver that is installed should be 2.3.1035.0.
If Windows Device Manager indicates a device problem, or if the version of the driver that is installed is not the current version, you must update the driver. To do this, follow these steps: 1. Right-click Zune or USB Device, and then click Properties.
2. Click the Driver tab, and then click Update Driver.
3. Click Search automatically for updated driver software.
4. Click Install if you are prompted to do this.
5. After the driver installation is complete, click Close.
If Windows Device Manager found the drivers, click Close. If you want to locate the drivers manually, follow these steps:1. In the Zune Properties dialog box, click Update Driver.
2. Click Browse my computer for driver software.
3. Click Browse, locate the \Program Files\Zune\Drivers folder, and then click OK.
4. Click Next.
5. Click Install if you are prompted to do this.
6. After the driver installation is complete, click Close, and then click Close again.
10. Examine the computer for conflicts that involve the USB host controller or the root hub. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
c. Expand Universal Serial Bus controllers.
d. Verify that no errors appear in the list of USB devices. A yellow exclamation point or a red "X" next to a device indicates errors. If any errors appear, contact the manufacturer of your computer.
For more information about how to troubleshoot conflicts in Device Manager, click the following article number to view the article in the Microsoft Knowledge Base:
310126 (http://support.microsoft.com/kb/310126/) Troubleshooting device conflicts with Device Manager
11. Try using a different Zune Sync Cable.
Apr 10, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I need to download the "ZuneDriver.dll" so I can make the software for the Zune player open. I have downloaded the software ".exe" file from the Zune site, but it fails to install because "Can't find the...
You shouldn't have to install the driver yourself! Uninstall and Delete all files connected to your Zune (except your music files!). Now, plug your Zune in, and the computer should locate/install all the necessary drivers and software needed to operate your Zune. Then, you can format/personalize the Zune software the way you want. The computer downloads the drivers for you! Try that! It should work wonderfully!
Dec 12, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Problem with intalling zune's software
Uninstall all zune software and download and install it again. Possibly a bad download.
Or run error check on your computer then try it again.
Go to my computer, right-click on C: - go to properties- then go to TOOLS tab. Click on Error check - make sure you have both boxe(s) checked to fix errors as they are found then hit start. You will have to restart your computer for this check to happen. Usually takes a a few hours, but recommended to do at least once every few months.
Hope this helps!
Aug 03, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune problem
Download and install the latest zune software from microsoft. Run the new zune software, plug your zune into the computer and it should prompt you to install the latest firmware automatically. This is all that is necessary with the majority of firmware problems.
May 12, 2008 | Microsoft Zune JS8-00001 Digital Media...
PC will not detect my zune.
Hey!! I just fixed mine! I had recently installed drivers for a PS3 controller, and for some reason those were conflicting with the Zune.
To fix it, I went to add/remove programs, and then removed the libusb program, that fixed it instantly! Good luck!
Dec 04, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
102 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
