Question about Philips VOIP8411B/37 IP Phone
"System Starting Up" message on the phone forever
"system starting Up" FOREVER and non of the turning off, un-plugging, re-plugging, de/re-registering, re-setting buttons work.
I'd love ONE solid answer to this problem thousands seem to be having.
Andres
I often have the same problem and haven't found the solid solution for it yet. But, for me usually helps doing this in following order:
1. restarting my router
2. unplugging the base for about 10 minutes
3. taking the batteries out for about 10 minutes
Hope it will work for you too.
Posted on Oct 30, 2009
How do get the original message back?
Text Message? Gone forever.
Email message accidentally deleted? Web interface - Deleted Items. Move back to Inbox or Sent Items.
Home Phone Voicemail message? Gone forever.
Home Phone Voicemail caller message? Gone forever.
Jan 17, 2016 | Lands Phones
I have the htc hd mini, and it freezes all the time and constantly vibrates, even if i have no message and itsfully charged. It turns itself off and takes forever to load when i turn it on. The touch...
Hi you will have to try doing a hard reset or factory reset to fix this issue . PLease follow the below procedure . This will reinstall all the drivers and reload the OS
Doing a hard reset will make you loose your data on the phone .
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the POWER button briefly and then release it.
  3. When you see a warning message on the screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Aug 08, 2011 | HTC Touch HD Smartphone
Check deleded messages
Im sorry, but once you delete a message on the Vtech system, it is deleted forever, Good to know for the next time! :(
Feb 15, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Salve , possiedo un samsungHT-DS400 che quando vado ad accendere mi appare sul display la scritta on protection per qualche secondo...per la samsung il pezzo che andrebbe sostituito non è...
Ciao Massi.
Come saprai, protection indica un errore generale, e non dice dove sia il problema. Semplicemente indica che il tuo Samsung ha rilevato un voltaggio incorretto, e che il sistema viene temporaneamente forzato in stato di standby chiamato protection (i Massive Attack ci avevano fatto su una canzone).
Il supporto tecnico Samsung non sa quale parte non funziona, semplicemente sospetta che il problema sia la PSU (circuito di alimentazione), la quale e' probabilmente il guasto piu comune in questi apparati.
Siccome le parti per questa unita' non sono piu distribuite (solo il telecomando e' disponibile), il supporto tecnico ha giustamente consigliato di sostituire il sistema.
Qui lista parti, le poche parti elencate non sono in stock.
Tutto quello che puoi fare e' assicurarti che le connessioni alle casse ed al sub siano intatte. Se un cavo fa corto, allora l'unita centrale segnala Protection.
Se il problema non e' un cavo balordo, l'unita centrale, il Sub, e qualcke volta ancke le casse (connessione ai coni in corto) devono essere aperti e testati da un tecnico.
Un lavoro del genere puo richiedere svariate ore, e generalmente non vale il prezzo dell'originale in un unita di questo tipo.
La riparazione e' fatta testando i punti di saldatura e i componenti, e richiede conoscenza tecnica.
Controlla i cavi, se non trovi niente, la riparazione puo essere fatta da un tecnico locale, il prezzo in Italia e' probabilmente tra i cento ed i duecento euro. Sono piu di dieci anni che io non lavoro piu in Italia e non saprei dire. Quando lavoravo li' la tua fattura sarebbe stata intorno alle 80/100mila lire un po meno se il problema si trova immediatamente (a volte puoi proprio vedere che un componente e' esploso, accade frequentemente con i condensatori dell'alimentatore, altre parti, come I chip del finale dell'amp, non mostranon alcun segno quando vanno male, nel tuo caso il problema non deve essere facile da identificare a prima vista perche il sistema ancora funziona, con un condensatore esploso il sistema rimane in protezione ).
Buona fortuna.
Ginko.
Sep 29, 2010 | Samsung HT-DS400 System
Retrieve deleted messages from uniden cordless phone
After its deleted then its deleted forever. These are not like the old answering machines that all you did was pull the plug and plugged it back into the wall outlet to retrieve old messages was were deleted. When digital you can not do that....Sorry
Jan 03, 2010 | Uniden Cordless Phone exai398i
My Palm Pre is frozen with only the word palm on the screen. I've tried all the troubleshooting I could...
It is downloading an update. It may seem to take forever. It will eventually restart. Sometimes they have taken as long as 20 minutes on my phone. When the word "Palm" starts glowing and "un" glowing, then you know it's about to turn back on.
Jan 01, 2010 | Palm Pre Cell Phone
Message deleted
By their very nature, home telephones are simple things.
Theres no fancy way of 'un-deleting' it, your message has gone forever I am sorry to say.
Apr 22, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Can't reply to txt messages it freezes
The phone may require to have its operating system purged and then reloaded. There may be some corruption in the system. The only other fault that can normally cause this is an intermittent hardware failure. The only way to know for sure is to start by having the operating system and all the software re-loaded as like when the phone was new. Don't add back any other optional non original programs until you established that the phone is working properly.
A common cause of damage to the operating system, is when people load in various non approved programs and utilities. Some of these programs may have errors in their code, and thus cause fault conditions.
We use Blackberries in our facility. When the users start to load in various programs from all over we start to have some very interesting fault conditions. Purging and reloading the complete operating system is usually the fix unless there is a hardware failure.
Jerry G.
Sep 25, 2008 | HTC Touch P3450 Smartphone
GE 28128
I called support - took forever to get through
Told to unplug phone line, batteries, and AC, then wait 15 minutes.
Then reintall in order of batteries, then AC, then phone.
But once the AC gets plugged in, the light starts blinking again.
The technology of bluetooth with my cell is great, but the interface sucks and the light that won't properly recognize things is incredibly annoying. This one is going BACK....
Oct 25, 2007 | Uniden Cordless Phone
Philips VOIP8411B/37 IP Phone Logo
200 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
