Question about Maytag MDB9100A Dishwasher
I have a greasy black residue in my dishwasher
The residue is on the walls and racks of the dishwasher and it also gets on any soft plastic items (tupperware, cups, etc) that I wash. It does not get on porcelain or utensils or hard plastic. It will come off the dishes with some soap and water and scrubbing but I haven't been able to get it off the dishwasher or figure out where it's coming from .
  • 30 Answers
SOURCE: Dishwasher Issues
I would try using a different soap or less of your current soap.
Posted on May 03, 2009
SOURCE: Soap remains in soap cup after complete cycle is run
I had the same problem. The door on the cup does not open all the way. Here is what I did. On the back of the dishwasher door are 7 phillip head screws. Take those out and the door inner cover comes off. There are 2 pieces of black insulation that are glued to the cover. The smaller one had slid down to where it was blocking the cup door from opening all the way. Pull this black insulation off and put it back in the right place. I even put a little hot glue under to keep it from sliding again. Hope this works.
Posted on Mar 21, 2008
  • 39 Answers
SOURCE: Soap residue on all items after dishwasher completes its cycle.
Hi Rioski
The first thing to do is where you put the jetdry turn it down to one. use powdered detergent the best is electosol is the blue box,dont use the heated dry feature and run the hot water at the sink first to get it good and hot that should fix the problem. I also recomend using GLISTEN every 6 months. its a citric acid that is designed to clean the dishwasher. i hope this helped.
brent
Posted on Oct 01, 2008
  • 677 Answers
SOURCE: dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Posted on May 10, 2009
SOURCE: GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
Posted on Jul 01, 2009
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
The water supply arm for middle sprayer is not held in place by clip that is attached to bottom of dish rack. Does not meet up with water outlet on back of washer and also impedes movement of sprayer arm....
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 11, 2011 | KitchenAid KUDS40CVSS Builtin Dishwasher
Some items are not completely clean at the end of the cycle. On plastic items there is a chalky residue.
heatman101
Nov 19, 2010 | Kenmore 24 in. 16362 / 16364 / 16369...
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
heatman101
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Cleaned plastic cups and bowls have a greasy film on them
water heater temp to low maybe new elements clean internal unit screens cascade complete jel
Feb 04, 2010 | KitchenAid Dishwashers
The items on the top rack never come out clean. there is always food residue left. it seems that the final rinse doesn't get to the glasses. we need to rinse them all out before the drying cycle starts...
heatman101
Jan 04, 2010 | Amana 24 in. ADB2500AW Built-in Dishwasher
Dishes not getting clean
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Upper Rack not cleaning
id try removing hte lower filter plate . 5 torx 15 screws will gain oyou acess to lower sump and 2 more torx screws that will acess you the chopper assy, prhaps filled with debris not allowing good water flow,
Mar 25, 2008 | Dishwashers
Residue left
make sure the screens in the unit are clear,also check that the wash arm holes arent obstructed or the arm isnt cracked at the seams.let me know.also is the unit getting hot?
Dec 13, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Jun 01, 2006 | Smeg 18 in. DWF410SS Slim-Line...
Maytag MDB9100A Dishwasher Logo
224 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
