Question about Saeco Magic De Luxe Espresso Machine
I have a 250ml bottle of saeco decalcifier and i want to use it doe my superautomatic Saeco machine ( the machine is equipped with auto descaling functiom please tell me how to use decalcifier at what proportions
4 Suggested Answers
mirran
  • 515 Answers
SOURCE: Saeco decalcifying liquid
Use 1/3 of it in a full tank of water
Posted on Jul 11, 2008
SOURCE: My Vienna Deluxe super automatic Saeco is needing
just run that amount thru, that's only about a cup full, ya could water it down by even 25% still be OK.
Posted on Jan 26, 2010
  • 1089 Answers
SOURCE: I don't have a manual and need to decalcify my
Don't use vinegar or CLR or any chemical used in the bathroom. Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Manual descale: To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
  1. If you have a non-rapid steam machine, just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
  2. If you have a rapid steam machine, turn on the machine and then push the hot water button. This turns off the rapid steam and allows you to run hot water/solution through the steam wand. Just open the steam valve and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes.
  3. Repeat step #2 for your type of machine. Do this until you have used the entire water tank of solution (approximately four to five cycles). Remove the water tank and rinse it with fresh water.
  4. Refill the water tank with fresh water and place it back on the machine.
  5. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set.
  6. Your machine has been decalcified. You may still have scale in your boiler, but not as much as you had before. To reset your descale light, hold down on the steam button for at least five seconds. You are ready to brew, once your boiler has heated up.
Posted on Oct 29, 2010
I have saeco incanto coffe machine and when I have turned on the machine message appears Ventilate.
hi,probably your machine is need decalcify. Try to turn on the hot water knob when you start the machine. Fill about 1 water glas with hot water from machine.If the ventilate is still appear-you must decalcifying machine with special liquid for descaling.
Jan 04, 2015 | Saeco INCANTO DELUXE Espresso Machine
What is the proper method to descale?
Yes, you should empty the bean hopper and put the solution in the tank and run it through.
Nov 09, 2007 | Saeco Vienna De Luxe Espresso Machine
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Keep getting "decalcify" message
Go to MENU and scroll down and find SIGNAL DESCALING. Select ENTER the machine will ask RESET , YES or NO. Select YES and ENTER.
Jul 12, 2010 | Saeco Royal Cappuccino Espresso Machine
How to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Jun 13, 2010 | Saeco Royal Digital Plus Coffee...
How much decalcifier do I use. Doesn't say on the bottle. Thanks
Hi Use 1 oz. for every 32oz of water. There is a program in your machine for descaling. Select it and open knob in front once you have the powder disolved. When you have finished go to the menu that says "reset descale" and choose "yes". Then set your water hardness in your menu to 4, and your machine will tell you when it needs to be descaled again.
Feb 07, 2010 | Saeco Royal Digital Plus Coffee...
How to decalcify royal digital?
hi my name is Lee Davidian here is your answer
Automatic Decalcifying Cycle
The automatic decalcifying cycle keeps the machine in perfect operating order. When prompted by the user, mineral buildups in the internal boiler can be dissolved and removed with Saeco’s decalcifying solution and a push of a button.
Jan 11, 2010 | Saeco Royal Digital Plus Coffee...
Decalcify
im not a saeco folks but i buy those machine on ebay and repair them decalcify ready to used mean its ready for you to put descaling product in machine and you press on it will start the descaling sequence if you dont whant to descale i sujject you do it if not go in our menu and push botton untill you see descaling finish or done thanks pierre p.s taking about descaling my machine vienna told me this morning time to descale it comme about every 3 months let me now i know those machine good
Jan 10, 2009 | Saeco Incanto Classic Espresso Machine
DECALCIFIER
No can not. You have to waste the beans to run descaler through the Brew Group.
For Descaler or Saeco Parts visit www.CeriniCoffee.com
Nov 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Decalcify?
I had the same problem with a Saeco Royal Digital. I ran the decalcifying liquid through the machine with the automatic descaling program as per the instructions on the bottle and the DECALCIFY message stayed up.
I solved it by going to the menu and selecting "Signal Descal." and toggling it from No to Yes. I escaped back to the menu and git the usual "Select Product".
Hope this helps.
Nov 05, 2007 | Saeco Royal Professional Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
998 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
