Question about Carrier Adit 600 Base with CMG G.729 Router Phone
I have optioned my Channel as DATA but I cannot cross-x it to an analog channel because it is optioned as VOICE.....How do I change the respective analog channel to DATA so I can Cross-X it?
  • 1 more comment
  • ajani_willis Oct 06, 2009
    Ok, so this is what I did....
    Disconnect 1:A:15 (2:7)
    Set 1:A:15 type Data (and this took)
    Try performing Set 2:7 type data ( and this will not work)
    I need to change 2:7 to Data so that I can cross-x Data channel
    I have an ADIT 600 which is sloted with 6 FXS cards............I have a customer that needs DATA Service. I have changed the respective Time-slot (15) to Data however I cannot change the port on the FXS card to type Data........Is this possible if not what kind of card is needed for Data services??...........I would be extending channel 15 to a customer router
    Sergeant:
    Champion:
  • 208 Answers
For data services, you need one of the following:
V.35 card (http://www.carrieraccess.com/dbfiles/marketing/card_specsheets_pdf/adit_600_v35_with_v54_service_card.pdf): That's if you want to connect the data channel to another router or device using V.35 interface.
Router Card (http://www.carrieraccess.com/dbfiles/marketing/card_specsheets_pdf/ip_router_card_spec_sheet.pdf): If you want the data channel to connect the networks.
Async Card (http://www.carrieraccess.com/dbfiles/marketing/card_specsheets_pdf/quad_port_tsr_service_card_spec_sheet.pdf): If you are using the data channel for serial terminal type application.
Other than than, you can still terminate the FXS port to an analog modem. In this case, all you have to do is to set up your FXS port as if it is an analog phone line.
I am very familiar with the Adit 600. If you have any more questions, I will need to know what you are doing the the data channel, and what equipment you are hooking up on both ends.
Posted on Oct 07, 2009
  • 11,896 Answers
There is no way to do this other than adding another capacitor on the board.
Posted on Oct 01, 2009
Toshiba LCD TV/DVD 15LV505 lost channels. Rescan = fewer channels. Now in Setup, when I press the remote down-it skips the Channel option. What must I fix/change in Settings to get the Channel option?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 08, 2016 | Toshiba Televison & Video
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
HI I have a problem with tech CS5121 5.8 GHz when someone calls me i pick up the phone i hear a noisy voice while im talking with the person at the same time he doesn't hear that voice, so it actually...
Most likely this is just "bleed" over interferance from another cordless phone on the same frequency and/or channel. For starters I recommend changing whichever you can in respect to these to see if this fixes the issue. You might have to change them a few times to find a good setting without the issue.
This could be a case of lines being crossed anywhere from the wiring at your phone all the way to the phone company. If you live in an apartment environment it is possible for it to be crossed with a neighbors line. Although less likely, it could even be crossed wires from different houses. This could also involve the phone companies wiring anywhere down to their main connections.
Hope this helps...
Mar 13, 2011 | Vtech CS5121 Cordless Phone
Hdlcd19wb series a - How do I get the channels in digital, rather than analog? I can't even click on the "dtv signal" option in the menu. All the channels listed to add or delete are analog.
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
Jan 01, 2011 | Sansui HDLCD-1900 19 in. LCD Television
Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
Jan 11, 2010 | Broksonic CCVG1935 19 in. LCD TV
ACIDENTLY DELATED ALL CHANNEL FROM MY HUMAX, NOW I CAN NOT GET CHANNEL BACK I HAVE ENTERED CORRECT FRQ/SYMBL ETC DETAILS.
1 - The correct sequence for  all channel data input: a.satellite name; b.frequency; c.polarisation; d.data/symbol rate; e.fec. Did you respected that for every single one?
2 - If yes then is the signal strength for each frequency above 80% ?
3 - Did you scanned all satellites after you have loaded the data?
Oct 04, 2009 | Humax Televison & Video
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Lands Phones Logo
Top Carrier Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Carrier Lands Phone Expert? Answer questions, earn points and help others
