Question about Maytag Neptune MDE5500AY Electric Dryer
SURGING I HAVE A NEPTUNE AND WHEN I PLUG IT IN THE LIGHTS ACT LIKE THEY ARE SURGING AND A BUZZING NOISE IS HEARD. EVERYTHING STILL RUNS JUST LIGHTS ARE DIMMING.
  • 833 Answers
I'm assuming you mean that lights in the house are blinking and that there is a buzzing from the unit. Sounds like a motor issue or a drum that has something which is overloading that motor. It is also possible that you have a defective circuit breaker that is arcing or an arc in the relay/timer board. If these hints are not helping, then I suggest you get someone in.
Posted on Dec 21, 2007
Heat Pump makes a surging/buzzing sound every 20 seconds
You might have a short going to your reversing valve. Check the temperature of all three lines out of the valve. The one on the left should be cold and the one on the left should be warm hot. . Check voltage to the valve.if it fluctuates that might be the reason for the buzz.
Mar 04, 2015 | Heating & Cooling
Hotub clicks and then makes buzzing noise when turned on.
does it blow a breaker? check to see what is going on by unplugging all the pumps, blowers lights and anything else plugged into the circuit board (heater too)
turn the breaker on once everything is unplugged and then proceed to turn the spa off, plug one item back in and turn the breaker back on.
Do this until you find the buzzing....
You may actually have a back relay on the circuit board causing the buzzing by not latching in when the pump or something is trying to come on.
Rod
Aug 23, 2011 | Home
Just wired intermatic timer - turned power on and heard a buzzing noise from timer, then nothing. Lights turned on momentarily, then off again. Checked the breaker panel - everything is still on. Did...
The timer might be defective.
What timer do you have?
Add a comment and describe the timer or give model number.
I have extensive files on timers.
Jan 15, 2011 | Garden
I have a neptune washer that makes a buzzing type noise when I hit the start button? from motor area. The belt and pulley into the unit turns freely. I did get it to start and the barrel did rotate then...
The buzzing noise is probably an electrical relay that controls the motor. They have a spring assembly on an arm. When you energize it it creates a magnetic field and pull the arm down into contact and starts the current flow to the motor. If it's buzzing, the relay is probably bad and need replaced.
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Samsung HL-P4663W TV. Last evening we heard a pop and then the screen started to shrink in size and a loud buzzing noise could be heard. The indicator lights on the front panel indicate that the...
After much research, it became apparent that the most logical culprit after the lamp was the color wheel. It has been replaced and the set is working again.
Aug 21, 2008 | Televison & Video
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Maytag Neptune MDE5500AY Electric Dryer Logo
135 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
