Question about Mitsubishi WS-65809 65" Rear Projection Television
I have an issue with the green convergence. It is
I have an issue with the green convergence. It is causing an outline of green on words and images
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
This is a common failure for this particular television. You should have a red blinking power light on the front of your set that will blink 9 times and this is your solution to your problem.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Posted on Oct 01, 2009
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
I have a 61'' Panasonic tv that is showing green and red outlines around the figures on the screen. It originally started as just green outlines. Any ideas on what the problem is would be great. Thanks
The convergence is off. The convergence is basically the assimilation of the image on the screen from the three "guns" behind the screen. There should be a menu option to align the convergence in the image portion of the menu. If this does not fix the issue, then your convergence chip might be on it's last leg.
Oct 23, 2009 | Panasonic Televison & Video
I have a Zenith 65 in. TV model #R65W28 serial #271-33220211. The words are blurry and there is a green outline on images in the picture even if i reduce color to black and white. what can i do to fix it?...
It sounds like the convergence drive circuit has gone bad. When that circuit goes the red, blue and green don't line up properly. Have a repair shop check it out. While they are in there have the shop clean the lenses and mirror.
Oct 16, 2009 | Zenith R65W28 65 in. Rear Projection...
Green and red outline on images but looks clear
Most of the time you can just correct the convergence through the television menu. All that needs to be done is line up the blue and red to the green. If the colors do not move then there may be faulty components in the convergence circuit.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 21, 2009 | Televison & Video
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My phillips model 60pp920217f
You may have to do the full convergence alignment for all three CRTs, as outlined in the service manual for your model. Do you have the full service manual for your set which outlines the alignment and convergence proceedures?
May 08, 2008 | Philips 43PP9202 43" Rear Projection...
Green and red outlines -- Help!
This is most likely due to a problem in sthe convergence circuit. Since it seems to get worse as the set is on, I would look first for poor connections around the convergence ICs. Bad connections can change the circuit characteristics enough to cause this symptom. Resolder the pins on these ICs. These are large blac ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Dan
Apr 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Television problem
The yellow is being caused by misconvergence of the red and green beams. Go into the menu and do a convergence setup. Should be under video or convergence heading. Your ops manual should tell you exactly how. If after setting the convergence you still have the problem your digital convergence box is bad and you will need a tech to replace it. About $60 to $100.
Jun 04, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
