Hp printer stopped printing with a "usb" error 237
Hp printer stopped with a "usb" stopped error 237. Ran a test print - that was fine. Checked all cables - they seem to be fine. Restarted computer. Changed USB ports a couple of times to make sure that was okay. Also getting a message that "printer is not responding." Looked at printer face and it said "busy". Turned printer off and restarted everything, including the computer. Still getting response "usb" error stopped 237
    President:
  • 1,653 Answers
The remedy is to reinstall the driver for your operating system which will be available at the mfr support website.
Also check the status of the USB on your PC by looking at the device manager.
Posted on Oct 01, 2009
Print queue shows jobs stacked well after jobs printed
Best is to uninstall printer from computer and reinstall it again. Worked for me.
Jun 07, 2017 | HP Officejet 7000 Wide Format Printer...
My hp deskjet f4140 will only scan and coy. It will not print anything from my computer. I used it last night and it worked fine , then it just stopped. Ive checked my devices and printers under my control...
is it giving any error while giving print command? goto start settings printer & faxes open the printer icon by double click .any job is pending in the queue? try remove the usb cable and check t below the pinter icon whether it shows off line?
Aug 04, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
HP 6280 Printer. Not printing. Ran diagnostics form HP software. No issues. Printer an computer are communicating. Can run alignment test and Diagnostic Print Page from computer without issue. ...
Well you definitely have a pc problem and not one of the printer. the printer just prints what it is sent and as you can print the alignment page that takes care of the printer.
You have reinstalled the driver but did you remove the old one first? I bet not. You should download the hp printer removal tool. Run it and after a restart then you can install the driver. Personally i would turn off the auto update feature as hp updates really mess things up.
I reckon after the reinstall the printer will be fine.
Jul 23, 2011 | HP Photosmart C6280 Printer
My hp f380 stopped printing. it copies fine but will not print. i have checked connections and ink. those are fine. what now?
Go on this link and download the utility program
http://www.fixya.com/support/r5095488-unable_print_hp_printer
Jun 26, 2010 | HP DeskJet F380 All-In-One Printer
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Oct 27, 2008 | HP Deskjet 3915 InkJet Printer
Printer not working
Hello Kathi1603,
Please try these few things to see if they will get your printer running again. First off, check to make sure your USB cable is properly connected at both the computer end and printer end. If that's OK..then power cycle the printer.. try to print a test page by going to the control panel from your start button and then select Printers and Faxes.. using the right mouse button for your printer, selcet Properties then pick 'print a test page' see if that works.. If that fails, then transfer the USB can;e to another USB port on your computer and retry all the previous things.. When all else fails, restart your computer and see if you can print a test page to your printer.. Hope this helps get you going..
Sep 28, 2008 | HP Photosmart C4280 Aio Printer
Len trying to help Carol in a panic trying to print her resume. The HP office jet 4315 All-in-one was printing and ran out of paper. Installed more paper and it wouldn't print. It's connected to an HP...
If you're in a hurry, save to disk or USB memory stick, and dash to Kinkos / Staples / Business Depot or any other copy center, to get it printed out.
If you've got time otherwise, shut printer off, then on, and try and print a test page using the buttons on the printer.
If successful, then proceed to the PC. Shut down, reboot, and check the printer status. If good, try to reprint.
Sep 16, 2008 | Office Equipment & Supplies
C3180 will not print as error occurs even when installed
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
The self-test report prints, containing the serial number and service ID.
This should tell you if it is a problem with the unit itself, or with communication between the unit and your computer.
Feb 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
Adjusting printheads - won't stop and keeps printing blank pages
Hi Did you have any print jobs sent to the printer before replacing the printhead. It seems that the printer is trying to print a job and since the usb cable has been disconnected and reconnected the printer is printing blank pages or misc text.
Dec 03, 2007 | HP Officejet 9110 All-In-One InkJet...
189 people viewed this question
jasbo
jasbo
