Question about Bushnell Trail Sentry 11-9200 Digital Camera
My trail cam keeps saying there is no sd disk in it, i have tried several disks and it still reads the same
When I insert a disk, it keeps saying to insert disk not reading data please advise
The drive may be dirty, try applying the cleaning disk, if problem persists open the drive careful check the rotating parts, especialy gears and tension belts, replace those weaks or damaged, replace.
Jan 14, 2015 | Roland SD-50 Module
How do I get my files off of an sd card(for a phone) that neither a phone or computer can detect?
hi this might help, ime not sure but try it, take card out of phone and put it in sd slot on your computer if it has one, if it dose not read the card, then go into windows explorer then computer and see if it is there, if it is then right click on it then press properties this will tell you if the card has anything on it, if it has then press it to bring up the info on the card, pictures and music and all data, hope this helps you...
Dec 18, 2014 | SanDisk 16gb Micro Sd Hc Microsd Memory...
When inserting SD memory card in reader it keeps saying insert disk into SD card. This is on my netbook.
your disk may be corrupted. try to insert some other card if still not recognise then need to replace card slot/
keep voting me
Jul 27, 2011 | Computers & Internet
My navagation system keeps saying that it "cannot read disk" please check disk. Do i need a new disk or is something wrong with my system? 2006 Jeep Grand Cherokee?
the the problem is from the laser (lens) of your navigation system. It cannot read disk because the laser (lens) is weak or dirty.
Its might also be that the disk you inserted into the system has some scratches or the disc is bad. Try several discs on the system.
If problem still persists after trying several discs, get the laser replaced and it should read disk again.
Good luck.
Nov 08, 2010 | Cherokee Jeep Grand RB4 Navigation, AM/FM,...
Bought trail cam need 1mg sd can only find 2mg where can I find the right sd
the 2mg will just fine. I read on their website that you can use up to a 16mg, but I have used only the 2mg
Dec 26, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Xo vision dvd player/receiver 1906 wont read my usb or SD disk.
Consult the manual, it should probably say something about external media.
Check what kind of disk format is supported by your player - some players will recognize an external usb disk (or a usb memory stick) only if it's formatted in FAT32 file system.
Note that if you format the disk on a Windows machine, it will only do it on drives with a relatively small capacity (i think it's up to 32 GigaBytes), but other operating systems (like MAC OS) can perform a FAT32 format even on drives with far greater capacity.
As for the SD disk (did you mean a SD memory card?), see what the manual says about the format type, have the card (disk) formatted in the supported format and see if that works, otherwise you might want to try other brands of SD cards - my friend has an Avia (not Aiwa) dvd player with a usb port and a SD card slot and it simply won't accept some brands or models of SD cards, but will work well with others and it also works well with USB disks and USB memory sticks formatted in FAT32 file system.
That's about all i could suggest, i hope you can get it to work.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Televison & Video
My rumor 2 won't turn on.
If you have a micro sd disk in your rumor, remove it, then try restarting again. This works in the Rumor and I'm guessing the Rumor 2 has the same bug that 'tries' to boot off of the micro sd disk. Once it starts up normally you can re-insert the micro sd disk.
Aug 30, 2009 | LG RUMOR Cellular Phone
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Dvd keeps reading no disc
It can be several reasons
1. Disk is upside down
2. Lens is durty. You will need to use CD/DVD cleaning disk for that
3. Disk is having diffrent region code or recorded in diffrent formate (for instance player playback disk recorded in NTSC, and you trying to playback disk in PAL formate)
4.Disk is recorded at higher speed (for instanse player markered X16, but disk is recorded at X24)
Good Luck
Dec 24, 2008 | Televison & Video
After power outage remote not working.
Hi, this is a bit basic, try turning of for about 1/2 hour, to enable to discharge, then try again.
( I have used this on industrial installations, with far to complex computers stuff inside, and that mainly works)
Apr 02, 2017 | Sanyo DVW-5000 DVD Player/VCR
Bushnell Trail Sentry 11-9200 Digital Camera Logo
67 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
