Question about Casio Exilim EX-Z750 Digital Camera
Pictures too dark with and without flash
I have a casio ex-z85a. I've only had it for a few months, its a 9.1 megapixel camera. When i first got it the camera worked great. Now the flash doesn't work consistently, actually only every so often even when the flash is turned on all the time. Regardless of the flash being on or off the pictures taken are so dark you can't make anything in them out. How do I fix this?
SOURCE: Casio Exilim EX-Z3 Displays turns off when taking a picture
I have the exact same problem. Casio wants the camera mailed in and charges $79 for a new LCD screen (if that is the problem). Any other suggestions?
Posted on Feb 29, 2008
SOURCE: system error 0e01 of casio ex-s100 digital camera
throw it away
Posted on Aug 05, 2008
SOURCE: overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Posted on Sep 16, 2008
leecom72
  • 4806 Answers
SOURCE: dropped my casio exilim ex-z85a camera and now
By dropping the camera you have caused some shock damage to the LED display so you will no doubt have get it repaired.
Saying that, if you copy the pictures to a computer you may find that the pictures are fine.
Regards.
Posted on Aug 11, 2009
SOURCE: I dropped my CASIO EXILIM EX-S770 7.2 7 MP
just force it back in - it happened to me and i had to pull it pretty hard but figured that it was broken anyway so might as well give it a go - camera worked fine afterwards!
Posted on Jul 21, 2010
Lost charger plus instructions for casio 9.1 camara Ex-Z85A+31014870A
Instructions are often easy enough to find online on Casio's website.
http://support.casio.com/manuallist.php?rgn=1&cid=001
Choose your model number from that site and you should be able to access the online manual. If you are looking for a new charger, best bet will be to order one online or try and fine a third party one from Best Buy or similar store.
Mar 02, 2011 | Casio Cameras
Flash doesnt seem to work on amy mode. Takes great pictures in natural light but at night time all pictures are dark and red
My camera is Casio EX Z150, flash light always off. Please help me! Thanks you very much!
Dec 27, 2010 | Cameras
Dropped my casio exilim ex-z85a camera and now when I take pictures, there are light horizontal striped lines running through the entire image
Regards.
Aug 11, 2009 | Casio Cameras
Taking photos with casio ex-s10 goes all white
It don't work shutter. You need in repair lens unit.
May 16, 2009 | Casio Exilim EX-S500 Digital Camera
Red light continually flashes, and won't take picture
I have seen this problem on the ex-s880 casio camera a few times sometimes you can go into the setup menu and reset the camera to default and that some times fixes it. it that does not work I have had to replace the flash circuit on the camera because the large compasitor is out and needs tobe replaces most likely this is your problem because of the flashing LED. Hope this helps its a great camera also you might want to check with casio because this should be covered under warrenty. If the camera was not dropped.
Mar 28, 2008 | Casio Exilim EX-S600 Digital Camera
Casio EX-Z57
Try playing with the background or lighting - ex: take pics during the day versus nite... use a white/light colored background versus something dark.
Make sure you have the flash set to "auto" or try the "red eye" setting.. I've had good luck with both of those.
Also make use of the zoom. Stand farther back and zoom in - versus being close up and NOT using the zoom.
Hope this helps :)
Mar 02, 2008 | Casio Exilim EX-Z57 Digital Camera
Problem with picture quality
Casio Technical Support Team may have a solution to this one for you
Jul 16, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera screen dark
It sounds like you broke the backlight on the display. I would contact Casio to find a repair center.
Feb 13, 2007 | Casio Exilim EX-S500 Digital Camera
Flash problems, Casio Ex-z3
Try resetting your camera. Sometimes it is just an issue with the flash charging. In rec mode press menu go to setup tab go up to reset press right arrow highlight reset press set If that doesn't work then u will have to send it in. :)
Sep 04, 2006 | Casio Exilim EX-Z3 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
87 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
