Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
My printer says 'unable to print 7a' what do i do?? it is a mfc-490cw
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
SOURCE: my Brother MFC-490CW won't print
Did you try onboard print test by pressing INK LEVEL button. I am having similar problem but color prints but black does not. The printer has built in diagnostics that walks you thru some troubleshooting steps. It has you repeat cleaning 5 times and then asks you to replace cartridges if test fails...than repeat tests and call customer support if that does not work. Which I may do soon.
Posted on Jul 25, 2009
eliza_syafik
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
Posted on Aug 12, 2009
komguy
  • 2306 Answers
SOURCE: mfc-490cw what's unable to clean 35 ?
That error says that the carriage is not moving properly side to side or the encoder strip is dirty or out of position. You have to look inside for scraps or encoder position with a flashlight and mirror or remove the top cover to correct the problem.
Posted on Oct 15, 2009
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
Print unable error 7a
Canon copier IR 2520 show error code of E000002 please help me
Oct 30, 2013 | Brother MFC-8880DN Mono Multifunction...
My mfc 490cw will not print black ink. What should I do?
Try to clean the print head 2-3 times,if not work you need to replace 100% the print head.If a have been usefut please give me a vote :)
Mar 14, 2011 | Brother MFC 490cw Color Inkjet...
The printer MFC - 490CW says unable to init. 5A and will not print any documents
here are the possible problems from most common to uncommon
1. you have crinked up paper inside the mechanism or some foreign object
2. pf encoder disk is in contact with the upper cover, possible encoder disk replacement
3. pf encoder board is bad, replace it.
4. replace the ink absorber box
5. replace the maintenance unit
6. replace engine unit
7. replace main board
thanks
if your not a repair person, I recommend you take for diagnostics.
Nov 19, 2010 | Brother MFC 490cw Color Inkjet...
Wont print, no cleaning function. Says unable to clean 46
<span class="f"><cite>www.articlesbase.com/.../<b>brother</b>-<b>mfc</b>-<b>490cw</b>-<b>multifunction</b>-<b>inkjet</b>-<b>print</b>er-<wbr>amp-lc61-ink-cartridge-1797776.html</cite> - <cite>United States</cite></span>
Aug 29, 2010 | Brother MFC 490cw Color Inkjet...
MFC-490CW does not print black ink, what can i do to fix this?
does it print in any of the other colours? if not, it sounds like one cartridge is empty and the printer will not print until you have full cartridges.
Feb 08, 2010 | Brother MFC 490cw Color Inkjet...
Mfc-490cw what's unable to clean 35 ?
Oct 15, 2009 | Brother MFC 490cw Color Inkjet...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
509 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
