Question about Seagate Computers & Internet
Do you have a power for a seagate hard drive
Do you have a power cable for a seagate hard drive #9y7644-560
  • 108 Answers
SOURCE: Lost driver for Seagate 9W2874-560.
See this link on the Seagate site:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=3.5-inch_Pushbutton_Backup_and_SATA_(eSATA)_External_Hard_Drive_Support&vgnextoid=fb163b5ff0b8e010VgnVCM100000dd04090aRCRD
Check your model number (should be something like ST3200823A-RK) against the list.
Posted on Jun 09, 2009
Teckies
  • 226 Answers
SOURCE: Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Posted on Jan 30, 2008
SOURCE: New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Posted on Nov 19, 2008
  • 36 Answers
SOURCE: my bios doesn't recognize my hard drive
Do the neccesary jumper cable settings. then manually detect it through your bios. If not detected, try to replace the ide cable. if still not detected, try to feel the hard drive if it spins, if not, the had drive is damage.
Posted on Mar 05, 2009
  • 4 Answers
SOURCE: How to open case: Seagate ST3160203U2RK External Hard Drive ??
This is one of the mean tricks that the industry uses to discourage people from opening things and then totally ruining them.
What about getting yourself a 5-star-shaped screwdriver? Ask your hardware store guy.
Too expensive? Well - I have a lot of different simple slotted screwdrivers. Normally I find one that fits into 2 corners of these "miracle screws". If you don't have fitting one use a cheap one that is slightly too large to fit and grind it down just to size.
The same trick works with the other kind of "discouragement screws" that have ALMOST a normal slot --- but there's an elevation in the middle of it. A slot screwdriver with a ground-in **** in the middle (Dremel tools work fine) does the trick.
Posted on Sep 24, 2009
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Cannot connecy power supply to unit
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall.
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Need a power cable
A user on the Seagate forums indicates that his uses a 12V 2A DC power supply. I would suggest, however, that you remove the hard drive from that enclosure and place the drive either inside your PC or inside another enclosure.
If all else fails, contact Seagate: 1-800-SEAGATE
Let me know if this helps!
Apr 05, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate hard drive will not power up
You have to be running NT, XP or Vista to access the drive. I take the power cable out, then plug it back in. Or try rebooting with the hard drive plugged in. Also purchase a USB Extension port so you can unplug the USB when not in use to stave off overheating. Go to Seagate and download Seatools. Also Download the source code for the drive while you are there.
Jan 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
hopes it works.
pls. confirm
Jan 30, 2008 | Seagate (ST3300601U2-RK) (ST3300601U2RK)...
Power supply for Seagate 400GB
Ebay or seagate.com may be a solution.
I've used those Seagate portables and 2 have caused problems.
Or disassemble the unit, remove the drive and buy a portable case or USB adapter.
Oct 16, 2007 | Seagate 400GB 7200rpm External HDD Retail...
Computers & Internet Logo
545 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
