Question about Cell Phones
Help Keeps entering 6's, tries to go online, tries to increase ring volume, keypad flashes....resetting by switching on/off or removing battery does not work. It's not water damaged. Help !!!
No its a keypad problem, ask to your neREAT DEALER TO REPLACE WITH NEW KEYPAD
Posted on Jan 02, 2008
Could be just a bug they didnt work out. go to the store and tell them about it. they should replace it.
Posted on Jan 01, 2008
Incoming calls only ring 3 times and then go to voicemail. How to I increase rings to 6. There is no "Additional Settings" on my Settings menu
it might ring more than 3 times but you dont hear the first few if you are on Increasing Ring Volume. change volume to fixed volume ring.
Dec 13, 2017 | Cell Phones
My Phone Won't Ring And Keeps Going To Voicemail. Which Frustrates Me and My Friend When They Try 2 Ring Me...
Go to your setting : and hit Sound or volume and see if you can increase the volume for the ringer.
May 24, 2015 | Cell Phones
Need to reset passcode on skylink g5 garage door opener
G5K Reset
  • Remove the batteries for 2 minutes
  • Remove the T-shaped cover at the back of the keypad
  • Below the ABCD switch, there is a 3 prong jumper
  • Move the jumper from [Left & Centre setting] to [Centre and Right setting]
  • Put batteries back in
  • Enter [7 6 5 4 #] (2 slow beeps must be heard, if not, repeat the process)
  • Move the jumper back to [Left and Centre setting]
  • Wait 2 hours and the MPIN will be [0 0 0 0 #]
If the reset did not end according to my instructions, do it 2 or 3 times more. Remember, the battery has to be out of the unit for at least 2 minutes before doing the reset.
To change the PIN:
  • Enter the current PIN, (factory default PIN 0 0 0 0), press *
  • Enter new 4 to 6 digit PIN, press *
  • Enter new PIN again, press *
  • You should hear a long beep
Note: You only have 5 seconds to complete the task otherwise it won't work. If you failed to complete it, simply do it over again.
For example, if you are changing the PIN number from 0000 to 123456, enter the following sequence, 0000, *, 123456, * , 123456, * .
Keep in mind that you need to do this within 5 seconds only.
If confirmed, the backlit LED flashes and the unit emits a long beep.
Jun 10, 2012 | Home Security
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
Imcrease ring volume, and length of ring time
To increase the volume, you need to do that from the settings in your phone and for increased length of ring time, you need to call your cell provider or you can do it yourself if you have access to your mobile plan online.
Please rate if helpful.
Thanks
Apr 14, 2010 | Lands Phones
Flash doesnt work, flash icon keeps flashing, E:91:01 flashing
Hi
Try to reset your camera, heres one way of doing it
1. Turn OFF cam & Remove the battery or the power supply
2. Turn the switch to CAMERA for about 30 sec then & Turn the switch to OFF
3. Install the battery or power supply. & Turn the switch to MEMORY
4. Open the LCD cover and press the RESET button ( small inner button )
5. You will be prompt to adjust date/time.
6. Take some pictures and test out your flash
or open up the setup menu, and look for intilize or reset to factory defaults.
That should solve it, if it doesn't then its a hardware issue possibly the flash is bad some parts may need to be replaced to fix it. Take it to a local repairer or your dealer if your in warranty.
www.advancecamera.com will offer a free repair estimate if your outside of warranty.
Sep 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Motorola v3i
my v3i keeps connecting to the internet by its self and flashes error GPRS or somthing like that,across the screen and no buttons work at all, removing the battery is the only way to stop it. please help.
Have the same problem? Click Here
Nov 15, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
