Question about Samsung Digimax A402 Digital Camera
Low light indicator allways on
Mine is a new camera and it allways shows 'low light' as indicator will allways be on
  • 1 more comment
  • Anonymous Feb 24, 2008
    I have the same problem
  • redspirit May 02, 2008
    what does this mean
  • goone Nov 22, 2008
    same problem here too
I have the same problem aswell
Posted on May 03, 2008
My subwoofer keep showing a red light when i switch it on, could it be a fuse fault?
Probably not. The red light indicate idle mode. The woofer might have an auto-sense switch. When activated the subwoofer turns on when an audio signal is sensed at the subwoofer input.
Such switches often have three positions:
Idle (Somewhat off, but not quite)
Auto (Turns on the woofer when audio signal is detected)
Allways on. (The woofer is allways on - you might hear humm in the woofer when no audio signal is present)
Apr 24, 2016 | Audio Players & Recorders
The indicator shows low battery after 2-3 shots. (batteries 3800 MAh are fully charged)
This seems to be a problem with the ist line. My istD does the same thing. Turning it on and off a few times helps with mine. Pentax has no solution.
Sep 24, 2010 | Pentax *ist DL Digital Camera
How to set up show battery on nikon cameras s220
The camera will show a low-battery indicator when the batteries start to run down. The only indication of a full charge is the lack of the low-battery indicator on the screen. There is nothing you can set up.
Jan 31, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Low battery indicator with new batteries
Dear friend please go in setting option on your camera and select your battery type there. after that restart your camera. The indicator will stop showing low battery. But also confirm that your new battery are fully charged. Waiting for your feedback.
Jan 30, 2010 | Pentax *ist DL Digital Camera
My v8 trailblazer 2007 allways showing "check gages light" and no temperature indication
the check gauges light is on because the temp gauge is not indicating, u may have a thermostat stuck open and the engine never reaches operating temp.
Jun 16, 2009 | 2004 Chevrolet TrailBlazer
Canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Nov 18, 2008 | Canon EOS Rebel K2 with 28-90 lens 35mm...
Kodak DX6490 Not Charging
mine did the same thing, only it hadn't been dropped. Turns out, the battery went bad. The repairman said that the life of those batteries is only about 3 years average. He also said the average lifespan of the camera itself, with frequent usage, was only 3 years! I am still hoping to get the auto focus fixed on mine though. I sure did love that camera.
Sep 03, 2008 | Kodak EasyShare DX6490 Digital Camera
Camera shutting off indicating low battery
I had the same problem, apparently if you're using a external memory card that can cause this problem...
I didn't know that but I contacted Samsung and got mine repaired.
They put a note in saying the power board was faulty in the camera.
Much, much better now. I can take pictures like I used to be able to!
May 12, 2008 | Samsung Digimax A7 Digital Camera
Disney Pix Camera
Change the battery. This is an indication the battery is low.
Jan 19, 2008 | Disney Pix Click Digital Camera
Battery problem
It probably lacked the power to retract the lens. I'd start with recharging the battery and see if that corrects the problem.
Sep 19, 2005 | Nikon Coolpix 5400 Digital Camera
Samsung Digimax A402 Digital Camera Logo
52 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
