Question about Toshiba 53H71 53 in. Rear Projection Television
Toshiba projection tv with lines on screen
I have a 52" Toshiba projection tv and the screen gets lines all across it like the screen is messed up and the the top part of the screen bows down. Have had a repair man say it is probably the convergence going bad, but he said that when that part goes bad you normally cannot unplug the tv and plug it back it and it work. On mine you can unplug it and plug it back it, sometimes it will work all day and sometimes it will do the same thing again & shut off, then the red light blinks on the tv.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
I have seen a lot of sets where the problem only happens when the set is first turned on---99% of the time one of the two STK-392-110 CONVERGENCE chips this set uses is Flakey--intermittant---The only way to know is replace both of the convergence IC's and see what you have---a bad IC can cause the set to shut down---and sooner or later the set will just shut down and not come on at all.
Let me know if you need more information about this type of repair as I have done hundreds of sets with this type of problem----every one I have ever seen where the convergence was intermittent----replacing the two IC's cured the problem.
REGARDS, SD TECH
Posted on Oct 01, 2009
Lines across bottom of screen
are they blinking lines or just straight across from one side to the other blinking lines is the dlp chip going ( they cost a bit to replace)
no blinking then the mirror could of moved in the back of the tv, happens if the tv is not on level ground. or the dlp board needs adjustment ( happens over time as the plastic moves when hot to cold all the time)
Mar 16, 2013 | Toshiba 52HM95 52" HDTV Projection...
Why would there vertical lines on my toshiba theater wide tv?
this sounds like a bad capacitor. If you want to fix it yourself and know how to solder on a pcb, then replace all of the electrolytic capacitors.
Nov 18, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black line across screen
I have a line across my rca tv at the top. 52" rear projection. Any ideas? Could it be the mirror?
Apr 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
Toshiba 53H71 53 in. Rear Projection Television Logo
230 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
