Question about Canon PIXMA MP780 All-In-One InkJet Printer
Doesnt print faxes or copies because the paper isnt picked up from the tray
    President:
  • 1,653 Answers
1. Remove any paper from the Auto Sheet Feeder and Cassette.
2. Select the paper source with [Feed Switch].
3. Press [Menu] repeatedly until 3.MAINTENANCE> appears.
4. Use [<] or [>] to select <ROLLER CLEANING>.
5. Press [OK].
6. When cleaning has finished, repeat steps 3 to 5 for a total of three times.
7. Load A4- or letter-size plain paper in the selected paper source and repeat steps 3 to 5 additional three times.
Posted on Oct 01, 2009
  • Karl Wright
    Karl Wright Oct 01, 2009
    Cleaning the bottom plate
    1. Ensure that there is no paper loaded in the Auto Sheet Feeder.
    2. Prepare a sheet of A4- or letter-size plain paper. Fold it in half along the long edge. Unfold the paper, then load it in the Auto Sheet Feeder with the outside edge of the fold facing down.
    3. Press [Menu] repeatedly until <3.MAINTENANCE> appears.
    4. Use [<] or [>] to select .
    5. Press [OK].
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Print to bypass
Before printing click the property button, go to papar tab, under tray select, change from auto select to by pass tray
May 19, 2009 | Sharp MX-2700N Color Copier
Paper in lower tray is not being "grabbed" by rollers to start the print or fax job.
I think you need to add some paper to it so that the printer will easily pick them,,,,or arrange the paper onto the tray..
May 17, 2009 | HP 4110 All-in-One USB Printer/Copier/Fax
The copy/receiving function will not work.
hi,clean feed roll if the feed roll out of use please replace it.
May 14, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
All of a sudden, faxes stop coming out and the window says something to the effect...''Place US Paper in Upper Tray''. If I turn the machine on and off, the display clears and faxes that are in memory...
The fax machine is trying to print fax recieved copies on the bypass feeder.
Check up the setup menu on the control console.
Fine fax recieve.
You should find a selection for fax recieved in which paper tray.
Check this area, any that have the bypass feeder, de-select it.
Make selections for 8 1/2 x 11 paper in tray one.
May 01, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Disabling the fax function
You can set the fax portion of the machine to manual receive like this:
"User tools"
"fax features" ok
"reception settings" ok
"switch reception mode" ok
"Manual reception" ok
"user tools" to exit
Thia will prevent the machine from picking uo any incoming faxes
....However, if the machine is jamming trying to print a 'fax' report, it will jam regardless of the feature you are using -they are unrelated. Depending on the cause of the jam, it could be a specific tray that is causing the problem, so you may want to remove the paper from that tray, and see how it works. The other reason, that is common for jams from one particular tray is that the size is set incorrectly. Check that the paper size dial on the tray is set for the appropriate size in the tray (including orientation).
If none of this helps, please describe the location of the jams, and I may be able to give further advice.
Apr 23, 2009 | Gestetner - DSm618d Digital Imaging System...
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
How do I get faxes and copies to print from tray 2?
That is an advanced feature, genrally this is known as Automatic drawer eligibility. However, I am not sure this device offers this advanced feature. Look for options to select drawers for your diff functions in your users manual. Sorry best I can say...
Jan 06, 2009 | Office Equipment & Supplies
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
103 people viewed this question
old marine
old marine
