Question about Olympus Stylus 730 Digital Camera
It said no font
I send my camera for repair and como back the same way. When I turn on it said: NO FONT
I lost the CD for my VGA PC camera webcam can you help me?
.Normal {margin:0.0pt; margin-top:0.0pt; margin-bottom:0.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Times New Roman"; font-size:10.0pt; color:Black; font-weight:normal; } H1 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:18.0pt; color:Black; font-weight:bold; } H2 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:16.0pt; color:Black; font-weight:bold; } H3 {margin:0.0pt; margin-top:12.0pt; margin-bottom:3.0pt; margin-left:0.0pt; margin-right:0.0pt; text-indent:0.0pt; font-family:"Arial"; font-size:14.0pt; color:Black; font-weight:bold; } The entire installation cd here: http://d01.megashares.com/index.php?d01=6b830bb. It‘s an image file that you‘ll have to burn to a cd. You can use a Nero, Imgburn, Roxio, or any program that will burn an iso image to a blank cd. Burn the cd, install the driver, and then start using your webcam!
Mar 30, 2010 | Radio Shack VGA PC Camera Webcam
Tip
Lens Error
This is probably the single most commonly encountered error among compact and bridge digital cameras. It may indicate that your camera needs repair (or replacement). Before you go that route, however, there are several things you might try. These are not foolproof and they're not guaranteed: if your camera needs professional repair then it needs professional repair.
There are many causes for this. One is impact, caused by dropping the camera or knocking it against something, especially with the lens extended. Another is dirt or grit in the works, jamming it. Ironically, one of the most common sources for the dirt or grit is the camera case. Cases tend to accumulate dirt and lint and other stuff, which eventually get transferred to the camera. Another cause is the camera getting turned on while the lens is obstructed. This can happen if the camera gets turned on inadvertently while in its case or a purse or other confined space.
Cross your fingers and try these steps in order.
  • Warranty: If your camera is still under warranty, take advantage of it.
  • Power: If you have an AC power adapter for your camera, use it. This is not the same thing as a battery charger, but instead a device intended to power the camera for a long time on AC power. If your camera has a Lithium-ion battery pack, make sure it's fully charged. It your camera uses AA or AAA batteries and you're using rechargeables, put in a fresh set of alkalines instead. The purpose of this is to get the maximum power to the motor. Try turning on the camera.
  • Air: Using a bulb-blower if you have one and a can of compressed air if you don't, try cleaning the area around the lens, where the segments normally extend. Be careful not to blow more grit into the works. Try turning on the camera.
  • Orientation-1: Still using the power source from the previous step, place your camera on its back on a hard flat surface like a tabletop with the lens pointing straight up. Try turning on the camera.
  • Orientation-2: If the previous step didn't work, turn the camera over so that the lens is down, and try turning on the camera. Sometimes the extra effort of lifting its own weight will jar it free.
  • Jiggling: This is pretty much the last resort, but since your camera is out of warranty and nothing else works, so what do you have to lose? Jiggle the lens with a fingertip as you turn the camera on. Side-to-side, up-down, clockwise-counterclockwise. Don't push down on the lens so hard that you keep it from extending.
on May 31, 2012 | Cameras
Tip
Flash From a Cameras on 3 Phase UPS
Possible interruption to customer load due to Photo Flashes. While testing a new service, we hope to be offering soon, the Dallas based engineering department has discovered that the use of a flash camera in or around the UPS may cause a fault in the unit that could result in the loss of power to the critical load. We have noticed two different scenarios: 1. While taking a picture of the inside of a running unit in the test lab, the flash affected the firmware,
resulting in a lock up. The unit did not transfer, it just shut off! 2. At an actual customer site, prior to doing a PM on a number of units, we wanted to test the new Thermal cam. Part of the test involves taking a digital photo. Upon turning the digital camera on while standing next to a UPS, the RF of the flash charge circuit was enough to interrupt the inverter drives. Fortunately, the unit did successfully transfer to bypass, but only after the loss of a few fuses.
on Oct 21, 2011 | Computers & Internet
I cannot make picture size smoller -cannon IXUS 960
Normal 0 false false false MicrosoftInternetExplorer4 Try to use this picture resizing tool http://www.softorbits.com/batch_picture_resize/ It works well!
Apr 30, 2009 | Canon IXUS 960 IS Digital Camera
Change font color for e-Mail
CAUSE loadTOCNode(1, 'cause'); This behavior can occur if either of the following conditions exists: • Microsoft Internet Explorer is configured to ignore specified formatting features in the Accessibility dialog box. • Outlook Express is configured to use plain text.
RESOLUTION
loadTOCNode(1, 'resolution'); To change the format of the text when you compose a message, use one of the following methods:
Turn off the Accessibility Settings loadTOCNode(2, 'resolution'); To turn off the Accessibility settings, follow these steps: 1. Click Start, point to Settings, click Control Panel, and then double-click Internet or Internet Settings. 2. On the General tab, click Accessibility. 3. Click the following check boxes as necessary to clear them: • Ignore colors specified on Web pages • Ignore font styles specified on Web pages • Ignore font sizes specified on Web pages 4. Click OK. 5. Restart your computer for the changes to take effect.
Change the Sending Format loadTOCNode(2, 'resolution'); Change the sending format to Rich Text (HTML). To do so, follow these steps: 1. In Outlook Express, click Options on the Tools menu. 2. Click the Send tab, and then click HTML under Mail Sending Format. 3. Click OK. 4. Restart your computer for the changes to take effect.
May 31, 2008 | Microsoft Office Outlook 2003 for PC
Huge font in Outlook 2003
pls set the font size of your software and then check
Sep 28, 2007 | Microsoft Office Outlook 2003 for PC
Printer font default
OKI printers tend to only print in the font size that you give it in the print options or the softwares printing properties that you are using, you will find that it just indicates the font size being printed if it changes back, this means it's set to 10 in the print properties or the actual programme print setting.
Aug 03, 2007 | OKI MICROLINE® ML390 Matrix Printer
Olympus Stylus 730 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
