Question about Texas Instruments TI-83 Plus Calculator
Pls help my problem is (3to the 4th and 5to the 7thpower)out side the parethesis is to the 3rd but inside the parenthesis no simbols of add,sub, multiplication or division. what do i do?
  • Texas Instru... Master
  • 8,073 Answers
I think there must be an implied multiplication, sometimes represented with a simple dot.
If I am correct you have to compute (3[^]4*5[^]7)[^] 3.
Here is picture of your calculation. E20 means x10^(20)
Hope it helps.
Posted on Oct 30, 2009
I am trying to add/subtract & multi/divide with a TI 30XS. I can't close the parenthesis. I'll enter the number, then x10n, the exponent, but when I try to close the parenthesis it display
Are you opening the parentheses in the first place? If you don't have a left parenthesis then you don't need a right parenthesis.
Could you post the exact sequence of keystrokes you're using?
Apr 04, 2013 | Office Equipment & Supplies
Hi , my 95 dicovery wont change to 4th gear? pls help? mean while i replaced the gear to a 5 speed. every morning, it wont change into 2 untill it gets hot and then changes normally till the 3rd gear and...
You may have a bad clutch disc or pressure plate. You may have a bad transmission. Have you checked the master cylinder? I guess it may be a release bearing. Has this been going on ever since you changed to a 5 speed?
Mar 01, 2011 | 1995 Land Rover Discovery
3rd and 4th gear ration is out how do i fix?
the rpm should go up before gear change, if the delay is not too long, then thats normal, however check to make sure your transmission fluid is at the proper level, you may also want to flush the transmission and add new fluid and filter.
Jun 24, 2009 | 2000 Kia Sephia
Seven boxes puzzle
1 2 3 4 5 6
. . . . . . 1
. . . . . . 2
. . . . . . 3
. . . . . . 4
. . . . . . 5
. . . . . . 6
first box is the 4 corner dots at top on left hand side
Biggest box is 4th across on first line 1st across on 3rd line 3rd across on last line and 3r up on last line on
next box bottom left hand 2nd across 3up, 1st 2up, 3rd across 2up, bottom line 2nd frm left.
next box is just about inside biggest box, slightly smaller
next box is also inside biggest box again smaller
th other 2 boxes are the same size of the one in the left bottom corner, 1 inside biggest box and then you should find the last on no bother.
Hope this helps
Feb 11, 2009 | Nintendo Professor Layton & the Curious...
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Instructions for model 1188
Hi Diana - To record your outgoing message, hold down your ogm button ( outgoing message) for two seconds and it will ask you to record a message. To play back your message, just push the same button and it will play your message. If you don't like it just do it again. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good day.
Jeff
Jun 11, 2008 | BellSouth Digital Answering System 2006C...
Texas Instruments TI-83 Plus Calculator Logo
35 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
