Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven does not lite
GE Profile Spectra XL44 model #JGBP90
The oven seems to be working in every way, ie controls all work to set the oven, however it does not get hot. The broiler works as it should.The stove top works correctly. The self cleaning function does not get hot either.
This is an electric start model and the heating coil of the electric start does not get hot and there is no gas coming out of the fuel rail.
SOURCE: GE Profile Spectra XL44 oven wouldn't light, stove top and broiler works
same problem any ideas
Posted on Mar 08, 2008
We have our second GE stove and it has started to do the same as the rest of you.  Our first stove began to suffer igniter issues after 4 or 5 years.  I called GE and was given a simple test procedure for the igniter using a multimeter that I don't remember and likely wouldn't post regardless lest someone do things incorrectly... In any event, as I understand, the gas flow is tied to the igniter temp.  As the igniter ages, the temp that it can achieve gets lower. Eventually, it hits a point where the temperature isn't sufficient to reliably ignite the gas and our problems start.  The solution is fairly simple.  Replace the igniter. So, call a repair person and tell them the problem.  They can come out and instal the new igniter.  Unless you are a licensed or certified repair person, DO NOT DO THIS YOURSELF.  Let the pros handle repair to gas appliances.
Posted on Jun 15, 2008
huuum
  • 750 Answers
SOURCE: ge oven profile spectra xl44
Hello ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You asked, is there anyway to bypass the oven lock or bypass the self cleaning mode to get oven working?
Why do you need to do this?
If the door lock is stuck in closed position and preventing you from using the range?
You may free this by following this procedure.
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects most problems!.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the lock switch itself is bad and if you think you can bypass it then you may as well change it. Same labor!!.
Let me know how it works out.
Huuum
Please remember to leave a rating.
Posted on Sep 25, 2008
RescueTech
  • 145 Answers
SOURCE: Bake ignitor Location
Hi Kurt, welcome to FixYA!
In the diagram below, Part #28 is your ovwn ignitor. (See the red markings to highlight it)
It is located underneath the oven floor, and the floor should come out by removing the two screws located in the bottom rear of the oven cavity. Take out the racks, take out those two screws, and lift the oven bottom up from the rear, then disengage the front lip and lift it out. I hope this is helpful info and thanks for allowing us to be of service to you.
a16646a.jpg to you.
Posted on Dec 23, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE XL44 gas: Stove works fine. Oven heater lite on but gas wont
Click on link below and go to page 46 on the Adobe PDF of your model and there are some trouble shooting tips. Thanks, Let me know if this helps, Sea Breeze
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Installation%20Instructions&SKU=RGB745BEAAD
Posted on Feb 08, 2009
I have a GE Spectra Profile XL 44 and I get an code F0. What does that mean?
Here is a tip that I wrote that will help you with the Xl44 profile error codes.
Oven Fault Codes for GE XL44 Oven
heatman101
Oct 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to lite the pilot of a spectra XL44
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra oven xl44 model # JGBP85WEB5WW oven will not heat
heatman101
Nov 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
