Question about NorStar Meridian M7310 Phone
When i press the intercom button there is not a dial tone on my norstar 7316 phone. Do you know how I can fix this?
  • ynotphone
    ynotphone May 11, 2010
    There could have been a recent change in the system, like have you moved a your phone recently to a new position?
    Press FEATURE * 0 (this is a key button inquiry, it will tell you what is on evey key of your phone)
    Press all the keys and make sure that they correspond to the keys being pressed(ex: call forward button is the call forward)
    There may have been changes to teh system and programming is required.
  • 52 Answers
First you should make sure you have intercom key assigned to your set. Press feature * 0 this is called button enquirey then press the int. key on your set to see what that key is . If you have not int key go into programming and assign int key to set.
Posted on Oct 31, 2009
How can I program an all call button on the NorStar Meridian M7310 Phone to intercom everyone in the office simultaneously?
I guess you want a page key programmed on your set. press feature *3, press a memory key, press feature 610. This key pages all sets when pressed.
Dec 07, 2016 | NorStar Meridian M7310 Phone
Dial tone nortel phone
It\'s in system programming: feature CONFIG, Terminals & Sets, enter ext #, Prime Line: set to I/C (for intercom dial tone) or Line xxx. It is probably set to None based on your description.
Aug 26, 2014 | NorStar T7316E Corded Phone
The keyapd on my meridian telephone sets do not output any tone after a call is complete.
Key pads are for buttons, not dial tone.
When a call is complete it should be silence.
If you want tone then press Intercom or a Line or an Access code.
Dec 17, 2012 | NorStar Meridian Norstar T7208 Corded...
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
I can't make a call or receive calls, I tried unplugging it several times and all the lights starts blinking!! When I try to dial a button, it gives me a busy signal.
You are probably trying to dial out on an intercom button. This will give you a busy every time. You may have to dial 9 to get out.
To test your phone, 1st find out what your intercom number is (press feature*0 and then press the intercom button) Your display will show you the intercom number of your telephone. Then try to make an in house intercom call to another working telephone. If that works have them call you back.
The next step is to find out if you have any lines programmed to your phone. (press "feature*0) and then each button on your phone. The display will show you what is programmed on that button. If you have any that say "001 Line001" or such those are the outside lines to dial out on. Hope this helps.
Bill C. www.dyna-tech.us We provide remote programming and tech support for Norstar CICS MICS and Call pilot 100/150.
Mar 11, 2010 | NorStar M7310 Corded Phone
Lines ring to intercom
It sounds like although they're labeled as line buttons actually they're programmed as station buttons.
If you press feature *0 and one of the buttons it will tell you what the button is programmed as.
Also did you try pressing the intercom button then dialing 9? that might be the way the set was programmed.
Mar 05, 2010 | NorStar M7310 Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Can't dial out
What are you getting when you try to dial out? Sounds or display wise? How are you dialing out? Do you access a line, dial 9 from intercom? The dial tone is probaly the phone system generated dial tone. With more information, I can help..
Oct 25, 2006 | Nortel Meridian 9417CW 2 Line phone
NorStar Meridian M7310 Phone Logo
217 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
