Question about Whirlpool Refrigerators
I have a Whirlpool EC3JHAXRSOO side by side. I need to remove the refrigerator side door. I have the proper screwdriver (a T30), but I can't get the screws to budge. Corrosion perhaps. Any tips on getting them loose?
  • 1462 Answers
SOURCE: door handle
removing the front panel is just meccano. the screws are probably torex - a driver is easily available from any tool shop
Posted on Mar 26, 2007
  • 833 Answers
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Posted on Dec 21, 2007
SOURCE: refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Posted on Mar 18, 2009
Maytag317
  • 1136 Answers
SOURCE: My side by side refrigerator handles are loose (Whirlpool gold)
Hi, Most newer models have a screw behind the plastic cover on the handle. Take a good look at the handle and see if the cover can be removed. It should just snap on. If not, please get me you model # and I can assist you further.
Thanks
Vic
Posted on May 14, 2009
Greg20
  • 149 Answers
SOURCE: refrigerator door handle is loose how do I fix it?
some come off when you pull straight up if there are no visible screws. then tighten the screws on the inside of the handle that fasten into the clips on the door.
Posted on Jun 12, 2009
How do I take inside door panel off
Tools Needed:
Flathead screwdriver (the pointier the end the better)
T30 torx wrench
Removing the panel:
Before the panel can be removed you must start by removing the bolts holding it on.
Begin by locating the black rubber square in the pocket on the arm rest
To remove it wedge a flathead screwdriver under it and pop it up
25120304-etqrlrti5hbclqlowkwdhbst-5-2.jpg Undo the 2 T30 Torx bolts holding the control panel down.
25120304-etqrlrti5hbclqlowkwdhbst-5-5.jpg Next is to remove the control panel. To do so, pry it up with a flathead.
25120304-etqrlrti5hbclqlowkwdhbst-5-9.jpg Once its up, undo the 3 connections and put it somewhere.
25120304-etqrlrti5hbclqlowkwdhbst-5-20.jpg Next pry open the cap in the door handle cubby (if someone can post a way to not break it that would be great)
25120304-etqrlrti5hbclqlowkwdhbst-5-27.jpg Remove the T30 torx bolt behind it.
25120304-etqrlrti5hbclqlowkwdhbst-5-35.jpg Next remove the button thing on the side of the door panel.
25120304-etqrlrti5hbclqlowkwdhbst-5-44.jpg To remove it, push inward on the inner circle and pry it off with a flathead
25120304-etqrlrti5hbclqlowkwdhbst-5-54.jpg To undo the bottom portion of the panel, start by pushing the flathead behind the panel
25120304-etqrlrti5hbclqlowkwdhbst-5-65.jpg Pull the screwdriver away from the door to release the pin. Do this along the bottom of the whole panel until all nine pins have been released.
25120304-etqrlrti5hbclqlowkwdhbst-5-77.jpg Finally before you can remove the panel. Stick the flathead behind the piece holding the tweeter and pop the pressure clip loose.
25120304-etqrlrti5hbclqlowkwdhbst-5-90.jpg To lift the panel off put your hands on the side off the panel and pull the bottom away from the door. Then lift up, releasing the panel from the channel at the top of the door. Lift it over the top of the lock pole thing.
The latch cable will need to be removed next. It is simply held on by a clip.
25120304-etqrlrti5hbclqlowkwdhbst-5-104.jpg Once the cable is released the final thing to do is disconnect the final remaining connections.
Once the connections are disconnected the panel can be completely removed.
25120304-etqrlrti5hbclqlowkwdhbst-5-119.jpg Doing the passenger side door is basically the same. The only difference is that the bolts are in different locations and there are only 2 connections
One of the bolts is in the door handle pocket, just like the drivers side
25120304-etqrlrti5hbclqlowkwdhbst-5-135.jpg Once again i managed to snap the little cover off again.To locate the other 2 bolts, you need to remove the metallic grey trim. Begin by sticking the flathead in the side of it
25120304-etqrlrti5hbclqlowkwdhbst-5-152.jpg Pry along the edges until you can pull it off
25120304-etqrlrti5hbclqlowkwdhbst-5-189.jpg The 2 bolts will be located under neath. Remove each of the 2 T30 torx bolts.
25120304-etqrlrti5hbclqlowkwdhbst-5-230.jpg Just like the driver side, you next need to undo all the clips along the bottom of the panel as well as the little button thing on the side and the pressure clip by the tweeter. Lift it up to release it from the channel and disconnect the cable and the connections.
When putting it all back together, just reverse what you did and it should go back together no problem. Just make sure (this took me awhile to figure out) that when you put the button thing in that you make sure the inner circle is popped out.
25120304-etqrlrti5hbclqlowkwdhbst-5-252.jpg Insert it with it popped out and then push the inner circle in.
Sep 20, 2014 | 2006 Pontiac G6
How to level a Whirlpool Conquest refrigerator 2009 after moving it from a different house? The left front now wobbles.
To level your refrigerator:
Remove toe grill. Use flat-blade screwdriver or 3/8" socket wrench to adjust the front rollers. Or Turn the leveling leg clockwise to raise the side of the refrigerator or counterclockwise to lower it. Which ever applies to your unit.
Note: Having someone push backward against the top of the refrigerator takes some weight off the leveling legs. This makes it easier to adjust the legs.
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Jan 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
FLAP ON THE ICE DISPENSOR DOOR WILL NOT CLOSE
look under the disp. cover.you will see 2 cut out were a falt blade screwdriver will fit into it.
stick you screwdriver in that slot and pry out careful not to crack the cover.
tip: press down w/the palm of your hand on the cover while prying up w/the screwdriver.it should snap off
Jul 14, 2009 | Whirlpool GS6NBEXR Side by Side...
How do I remove the icemaker trim on the frontof
Use a very thin flat head screwdriver and slide it under the door and the edge of the plastic cover gently pry until you can grab it with your fingers and pull , start at the bottom first the panel will pop all the way off and then there is usually a harness cable to detach.
Phil
Apr 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Removing Doors on Whirlpool Gold GS6NHAXVQ side by side fridge
remove the kick plate (lower grill) on the freeezer hinge is a tube folow that tube to a disconect, unscew the nut then remove the nut from the tube then remove the top hinge and lift the door off the lower hinge threading the tube through the lower hinge.
Dec 24, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice/Water Dispenser
Squat down and look up at the bottom of the cover where it meets the door. You will see two shallow slots where you can fit a flat bladed screwdriver to "pop" the cover loose. Once popped loose, disconnect the electrical connector by bending the locking tab out.
Aug 12, 2008 | Whirlpool ED2NTGXL Side by Side...
Whirlpool ice maker door shute
look at bottom edge underside . put screwdriver in slot as vertical as possible and pry by turning screwdriver clockwise while stillholding vertical.repeat at ather slot
Jan 29, 2008 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Whirlpoor model ed5phexnqoo
first remove the drip tray.then look at the bottom of the panel.you will see two slots on either end.find a wide slotted screwdriver and stick it in.twist until it pops.it will feel like it's gonna break,but it shouldn't.depending on how old it is,whirlpool put in a heated door.the new ones don't have a heater and work alot better.i normally replace all the parts at once(comes in a nice kit).be sure to unplug it.there is 110 volts running to those switches and panel)
Oct 14, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
