Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
97 Chevy Truck starts and idles rough and then shuts down
For the last month or so, every once in a while when I would start my truck it would idle for about 5 seconds and then shut down. I would immediatley start it again and it would stay running. I had no missing and the truck ran fine. Last night, I tried to start and started experiencing the same issue but each time I tried to start it, it would run for about 5-10 seconds and cut off. If I tried to give it gas it would backfire on me. Please help. 97 Chevy Truck has 135,000 miles on 350, plugs, wires, valve replaced at 100,000. Did not replace distributor cap and rotor. Want to know if this sounds more like an ignition control module issue or distributor cap and rotor issue.
  • 18 Answers
Sounds like you're loading up with fuel. I'd check the fuel pressure regulator. Some engines are set up with a regulator inside the intake plenum, which requires plenum removal.
Posted on Oct 01, 2009
    Problem Solver:
  • 16 Answers
Your 1997 Chevy pu has a throttle body injection system(TBI). I think your problem may be in the TBI carburator. I just fixed my 94 GMC that was
doing that with a clean used TBI carb. When you start yours try patting the
accelarator pedal and see if it trys to continue running.
Posted on Jan 20, 2013
Done an alt. change after doing a tune up truck ran than just shut down now will not start
Truck ' DIY Forums
www.diyforums.net/truck-2418/
My 2003 chevy Silverado V6 truck turns over but will not start..it acts lik. ... iS IT HARD TO REMOVE AN OIL PAN ON A 4.3 VORTEC S-10 PICK UP TRUCK ...silverado 1500 ext. cab. my problem is while driving on the highway my truck ... mytruck then took off the terminal to see if the alternator was work and now i have no .
Chevy Silverado and GMC Sierra Stalling Problem - Car Forums at ...
forums.edmunds.com > GMC > GMC Sierra 1500
Apr 4, 2008 - 30 posts - ‎22 authors
I can feel the truck hesitate or bump while changing lanes on the highway (70-80 MPH) if it ... Now it idles ... My truck has a 4.3 with automatic. trucks runs great after about a hour it .... It will idle and drive just fine, but will simply shut down. ... the not firing problem, but shuts off after it finally decides to start. Chevy Silverado and GMC Sierra Gasoline Engine ...
Jun 14, 2010
Chevy Blazer Fuel Pump and Pressure Regulator Problems
Mar 10, 2010
Chevy S10 - GMC S15 and Sonoma Stalling/Dying ...
Dec 14, 2007
Silverado starting problem...
Nov 15, 2007
More results from forums.edmunds.com
Dec 26, 2015 | 2004 Chevrolet Chevrolet Silverado 1500...
I have a 97 chevy and my truck is ideling rough so with truck running i unplug the maf sensor and truck died instantly plugged back in fired right up and also with truck running i unplugged iac agian truck...
The MAF Sensor measures air flow & temp,unplug it shuts off
The IAC-idle air control-unplug shuts off
It means you need to pay a professional to find a problem
Dec 03, 2014 | Cars & Trucks
97 3.9 dakota when it's cold outside and I start my truck it'll start right up but idle down til it quits . Start it again and it will idle.. Go down the road and it misses bad until it warms up. After it...
Here are the most common causes of idle surge, rough idle esp when cold and stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Jul 09, 2017 | Cars & Trucks
94 chevy astro rough idle and surge when driving
check throttle body and check for codes
Feb 06, 2013 | 1994 Chevrolet Astro
96 chevy s10 v6 stalls after i start it up
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 18, 2012 | Cars & Trucks
Ok got a 96 s10 2.2 when it first starts up it has a rough idle then it clears up, then whenu rev it up it does fine but when the rpms drop down it starts a rough idle and it wont rev up near as smoot
had same problem in 97 dodge truck turned out it was vaccum leak hard to find sprayed either around vaccum lines when idle went up found tiny hole in line
Sep 22, 2012 | Chevrolet Vehicle Parts & Accessories
Truck shuts down when it goes to idle
Hi.
Check idle air control system. The system comprises a valve that allow extra air into the engine when the engine is idle. If the valve is stuck, if there is a problem with IAC wiring or solenoid or if the vacuum hose connected to the IAC has a leak you get engine running rough and turning off when idle.
Check air intake and sensor (MAF and AIT). Replace air filter. Air intake problems may result in rich mixture and in engine turning off.
Check EGR and PCV valves. These parts may cause rough idle. When the problem is EGR or PCV you usually get troubles also when driving.
Dec 15, 2011 | 1999 GMC Sonoma
I have a 97 grand prix gtp that will start but wont hold an idl
bad fuel pump.- just replace it and your good to go!
Feb 21, 2010 | 1997 Pontiac Grand Prix
Black smoke when i start engine, very rough idle.
sounds like possible a sensor went bad or is loosly connected. O2 sensor??? Also check the air filter. Sounds like whatever it is, is making the truck run rich----that would be the black smoke.
Hope this helps
Aug 08, 2009 | 1999 Ford Super Duty F 450
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
1,041 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
