Question about Maytag Atlantis MAV6000 Top Load Washer
Burning rubber I went into the laundry room today and smelled something like burnt rubber and the washing machine was stopped on the rinse/spin cycle and is filled with water and clothes and I couldn't get it started
    Brigadier General:
  • 3,513 Answers
Hi
You have a broken motor coupling, while you are down to the pump check for something jamming the pump,..
Please follow the procedure...
First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft.
Thanks for contacting Fixya.com
Posted on Oct 01, 2009
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
Washer smells like burnt rubber
What is the make and model of your washer? I had a similar problem with my Maytag - there was a burnt resistor on the control board. We ended up just buying a new washer since the cost for parts alone was close to $400...the labor would have been a DIY-thing (15 minutes easily for the greenest amateur).
Nov 28, 2011 | Washing Machines
Washing machine + burning smell
The load of rugs may have been too much for the device and there may have been considerable belt slippage causing the burnt rubber smell. Try another regular load and cross your fingers. And stay away from those outrageous loads!
Sep 06, 2017 | Admiral AAV7000A
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Jan 24, 2007 | Maytag Performa PAV2200
Maytag Atlantis MAV6000 Top Load Washer Logo
236 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
