Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Act light green link light orange is this correct?
    President:
  • 547 Answers
Yes, that's the correct color for each of those lights.
Posted on Oct 01, 2009
Mp220 absorber full check printer 5b00
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the
Destination settings procedures.
6 times Green Print head deep cleaning
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal)
9 times Green CD-R print position correction
(vertical)
10 times
or more
Return to the menu selection
Feb 05, 2014 | Canon PIXMA iP3300 InkJet Photo Printer
1999 jeep grand cherokee fuel pump? Driving 60 mph and it died out of nowhere. No sputter,no dummy lights, no warning, just died.Acts like not getting fuel.Turns over and acts like it wants to start but...
Hello! Can you hear the fuel pump running when key is in Start? If not, lets check the one sensor that is a known failure when vehicles age...Located on the Throttle Body is the Manifold Absolute Pressure (MAP) sensor...It has a 3 wire connector...Orange (+5volts)...Dark Green/Orange (Signal lead)...And Black/Light Blue (Ground)...We need to eliminate this sensor first...Do you have a meter and a wee bit of experience using it? If so...Set it to read 5 volts...Using two safety pine push the point into the rear of the MAP'S in-place connector into the Dark Green/Orange and the other into the Black/Light Blue...Clip the (+) meter probe to the Dark Green/Orange safety pin and the (-) probe to the Black/Light Blue...Turn the key on...You should read somewhat less than +5 volts...Send a comment with results...See picture below of MAP sensor...Since I don't know which engine is in the vehicle 4.0L or 4.7L , I'll send both MAP"S.....Guru....Saailer
9_27_2011_9_36_25_pm.jpg4.0L DELPHI Part # PS10022..cost$ 110.00
9_27_2011_9_39_26_pm.jpg 4.7L DELPHI Part # PS10042 cost $110.00
Sep 25, 2011 | 1999 Jeep Grand Cherokee
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
My Canon Pixma IP400 is not working and the orange light is flashing 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release theresume/Cancel button. (DO NOT release the Power
button.)
While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
I950 printer - middle green light keeps changing to blinking amber color then back to green and does not print. Frank Grande fpadten@comcast.net
Issue: Power light (or Alarm and Power lights) alternate(s) between orange and green
Solution: The i950 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service.
Copy and paste the link below to locate an authorized service facility and obtain further instructions.
http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=232&modelid=8719
Dec 10, 2009 | Canon i950 InkJet Photo Printer
Canon S300 printer. 7 orange blinks, 1 green. I
According to the manual found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=6609
7 orange lights represents a bad print head, and the printer will need serviced or replacement. Since printers are so cheap lately, I would just go shopping. Hope this helps! Thanks!
Oct 21, 2009 | Canon BJC S300 InkJet Printer
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
selectable.)
button.)
Power
in
4) When the Power LED lights in green, press the
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
in servicing.
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
881 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
