Question about Motorola Mobility RAZR V3
Keypad sound how do I prevent the keypad from making a tone when I am dialing a number. I would like the keypad to be silent
  • Pastis May 29, 2008
    I, also, am trying to figure out how to get rid of the keypad sounds/tones. It's very distracting to others. I don't like it.
    Kristen
  • brekryglas Dec 18, 2008
    How do I make my keypad silent?
    Brigadier General:
  • 7,752 Answers
Scroll to settings>ring styles>key volume
Posted on Dec 21, 2007
Phone #2stoped ringing, no sound when dialing etc .
go back to that base station and ensure that it recognizes the bedroom phone
follow the user manual to install other phones
the bedroom phone has to be the same exactly and not earlier versions or different makes
Feb 24, 2016 | Panasonic KX-TG6632B 1.9 GHz Digital DECT...
How do i silence the keypad without putting the phone on silent on a LG A133 Ailica
Its quite simple. Just go to your phones tone settings and silent the keypad tone. This will silent the key tone.
Regards, polysandy
May 07, 2011 | Cell Phones
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
How do i turn off the keypad tones without making the whole phone on silent?
There are two places it could be in. The Profile and the Sound settings. Check both and set keypad tones OFF.
Mar 03, 2010 | Samsung Cell Phones
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
Can't dial out,
It sounds as though your system is set to pulse instead of tone, look for a switch on your phone to indicate pulse or tone, change to tone.
Dan
Jul 29, 2009 | Vtech CS5121 Cordless Phone
I can't turn off the keypad tones on a LG Xenon phone
To turn off the beep on the keypad beep or voice on an LG Xenon, go to menu; settings; sound; volume. From there you can raise or lower the volume or mute the keypad and other sounds.
May 25, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Key pad tones
after changing to beep activate which profile did you select
Jan 06, 2008 | Samsung SGH-D900 Cellular Phone
Motorola Mobility RAZR V3 Logo
545 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
