Question about LG CU500 Cellular Phone
I need settings picture messagig and internet
How do I receive pictures through text do I need internet
to receive text pictures, i mean the ones composed using alphabets in black and white screen, no internet is needed. but to receive the pictures in color, like the camera clicked, or phone clicked, you do need internet connection, that would again be a data connection or a wifi connection.
Feb 03, 2015 | Net10 ZTE Merit Z990G Prepaid Cell Phone
I have an unlocked HTC touch pro2 Verizon phone and use it with T-Mobile. I can receive calls, make calls, send texts, receive text, but I cant access internet or receive picture messages via text. Any...
Welcome to Fixya. The reason why you can't use the internet or receive a picture message is because you need to save the GPRS and MMS settings of T-mobile on your phone. For the settings you need to contact the so that they can provide you the right settings like the APN the HTTP link and other settings. after you have save the settings you will be able to use the internet on your phone and will be able to send and receive MMS.
Thanks
Aug 02, 2011 | HTC Touch Pro Smartphone
I cant send picture messages on the phone anymore
U must need to connect with internet.when 2 phone have active mms setting,and internet setting than u can send mms/photo.for internet setting talk with ur sims service provider.
Jun 30, 2011 | Cell Phones
The internet and receiveing pictures and sending pictures
First you need to restore factory settings . After that you need to call
the service center of your operator for receiving gprs settings .
and for activating your SIM card to access the web .
if this is helpful then rate please .
good luck .
Feb 04, 2010 | Motorola Mobility A1200
My razor will not send or recieve picture messages?
Attempt to access the internet.
If you are unable to access the internet, it is an issue with internet access. If you are able to access the internet, it is an issue with the picture message settings internally with your service provider.
The internet is necessary for a picture message because the picture is an attachment on the text message. The attachment/picture is downloaded via the internet and without the internet, it cannot be downloaded.
Regardless of whether the phone can access the internet, it will need to be troubleshot by a member of the technical support for your phone company. Contact them at your earliest convenience to have this issue fully resolved.
Jan 02, 2010 | Motorola Mobility RAZR V3i Cellular Phone
How do I set up ATT Internet connection in the United States?
at&t does not sell the M7500. You will most likely have to input the browser,mms and possibly the sms settings manually. If you go to www.wireless.att.com ,click support and choose a model close to what you have, you will next be taken to a page with a link to tutorials. Use the browser settings tutorial for internet,mms settings for picture messaging and so on. You need to have internet to send the pictures.
Sep 01, 2009 | Samsung SGH-M7500 EMPORIO ARMANI Cell...
Internet settings, picture messaging
You can download settings from here...
http://www.sonyericsson.com/cws/support/phones/detailed/phonesetupwap/k610i?lc=en&cc=gb
just fill in required info from drop down boxes and S/E will send settings to your handset like a text message. It should prompt you to save/install, and then may ask to set as default? Select YES. Finished.
These settings will set up mobile internet which is used to download/upload the pictures, and MMS settings that enables your phone to handle the message for your network.
If you still have problems after doing this you may need to speak to your network provider as they may need to change some settings that you cannot see?
Hope that helps?
Apr 27, 2009 | Sony Ericsson K610i Cellular Phone
Can't send or receive picture messages or download anything
In most cases, you need internet feature on your phone to use the picture messaging (MMS). In your case the free feature for internet should work fine. Keep in mind that you may be charged around $0.01 per kilobyte. The error you describe confirms the internet connection is not available and is causing the issue. This may simply be because the internet settings in your phone do not match the provider's settings. This happens when you buy an unlocked device. You will need to contact your provider to get the correct settings.
Apr 19, 2009 | LG Shine CU720 Cellular Phone
Cant receive pictures or send
No, but you will need a working GPRS connection to receive MMS messages. This is the same like you need for internet services. Check if GPRS is available. If you need settings for it, find them here.
Feb 13, 2009 | Dual Electronics CECT P168 Cellular Phone
AT&T, cant get use internet or sent picture messages
these setting are normally supplied by the provider.
You will need to contact them again and ask them to send you the WAP and GPRS settings.
These will come as 2 separate txt messages.
open each message and the phone should promt you to save the message.
save each message.
then go to your browser settings and set your provider as the default or prefered setting.( this should get internet working )
for the pics you will need to send a pic to yourself first to activate the settings between the phone and the network
Nov 06, 2007 | LG Shine KE970 Cellular Phone
LG CU500 Cellular Phone Logo
15 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
