Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My jandy pool control panel has gone dark as if it has no power. is there a fuse or something of that nature that i can check?
    Problem Solver:
  • 5 Answers
Had the same problem. I turned out to be a short in the Jandy Automatic Valve. The 3A fuse on the board kept blowing when replaced so I unplugged every component on the board except the power. Upon doing this, I was able to replace the fuse without blowing. Then I reconnected each component checking the fuse each time. When I replaced the JVA (jandy valve) the fuse blew again. Now, I just run without the valve plugged into the board and it seems fine. My aqualink is 7 years old and lately, it has been nothing but problems. I'm ready to go to simple timers and trash the whole thing.
Posted on Oct 09, 2009
  • aenchbachert Nov 08, 2010
    I echo your last sentiment-- I just want a simple timer.
  • 21 Answers
Check the breaker that is marked rs in jandy service panel first.Then check the red terminal bar in the upper left corner of service panel. It may be unplugged or have loose or broken wires.then check the red terminal bar on the inside remote
Posted on Oct 02, 2009
My Jandy rs control panel 7751 has gone out?
Yes! Although you the lighting is part of the circuit board, you can order a NEW Circuit Board and install it yourself! Shop around I believe we paid about $375 about a year ago.
The new circuit board should come already pre-wired with a connection plug. Disconnect power to the unit at the breaker. Gently pry off the cover to expose the old circuit board and plug. Gently wiggle the old plug off and attach the new board. I believe there are a couple of screws holding the board in place. The new board should come with instructions as well. If you are at all handy.... save yourself the install fee from the pool tech!
Mar 24, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy LXI gas heater. no power to the universal controller interf
wireless system to aqualink heater must be hard wired to aqualink by either 4 pin connector or firemans switch
May 09, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Where is the 3a fuse on a Laars lx heater? My control panel will not communicate with the heater.
I believe this fuse is on the top right of the board under the panel. I could be wrong but two screws on the bottom of the control will let you pull it out and see. But I'm suren it is on the circut board. good luck and let me know.
Oct 24, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
No readout on the display panel
not power to the system check for voltage if 220 or 110 check the fuse
Jul 03, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy heater not starting
FL 4 is igniter failure.
1. check the fuses on igniter wire as well as the wires.
2. replace igniter
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Getting error code 188E on Jandy Model LT Lite 2 pool heater. also control panel keeps flashing. Anyone know why
press the arrow key for 10 sec this will reset the heater. if code replace control board, if not enter time date and set temptures for pool and spa
Jun 06, 2009 | Jandy Digital Lite2 Lj250 Btu Heater,...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
700 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
