Question about Sony Playstation 3 (PS3) Console
I have wireless internet and on my ps3 is shows I have wireless enabled and its still telling me need an ip address and ethernet cable.
    Problem Solver:
  • 10 Answers
Reset your ps3 and try to run a hard wire to it. see if that works
Posted on Oct 01, 2009
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
I have a belkin n router model f5d8236-4v1,and im trying to get a open nat for my ps3 so i can host games anyways. i called my isp yesterday and asked them to bridge my modem and i got my pppoe user and...
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to completely bridge the modem
Dec 21, 2010 | Belkin (F5D5231-4) Router
PS3 and Internet connection using Ethernet - from a mac
Where did you obtain the IP address?
If you went into System Preferences and saw the PS3 there and copied the assigned IP address, then it should work.
Apr 25, 2009 | Sony PlayStation 3 40GB System
PS3 Wireless issues
Network settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet using an Ethernet cable.
1. Connect an Ethernet cable to the PS3™ system.
2. Select (Network Settings) under (Settings) in the home menu.
3. Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
4. Select [Easy].
After you confirm the network configuration, a list of settings will be displayed.
Depending on the network environment , additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
5. Save your settings.
6. Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
7. Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Internet Connection Settings (wireless connection)
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1. Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2. Confirm that an Ethernet cable is not connected to the PS3™ system.
3. Select (Network Settings) under (Settings) in the home menu.
4. Select [Internet Connection Settings].
5. Select [Easy].
6. Select [Wireless].
7. Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
8. Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
9. Check the SSID for the access point.
10.Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
11. Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12. Save your settings.
13. Test the connection.
14. Confirm the connection test results.
Internet Connection Settings (advanced settings)
If you are unable to connect to the Internet with basic settings, change your settings as necessary. Adjust each item as necessary for your particular network environment.
1. Select (Network Settings) under (Settings) in the home menu.
2. Select [Internet Connection Settings].
3. Select [Custom].
Adjust each item as necessary for the network environment in use. The items displayed vary depending on the settings you have selected.
Connection Method
Set the method for connecting to the Internet. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Wired Connection
Make a wired connection using an Ethernet cable
Wireless
Make a wireless connection via a wireless LAN
WLAN Settings
Set the SSID of the access point. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Scan
Scan for a nearby access point.
Select this setting when you do not know the SSID of the access point. The system will detect nearby access points and display information on the SSID and security settings.
Enter Manually Specify the access point by entering its SSID manually using a keyboard.
Select this setting when you know the SSID.
Automatic U
Use the automatic setting feature of the access point.
This setting is available only in regions where PS3™ systems that support this feature are sold. Select this setting when using an access point that supports automatic setup. Follow the on-screen instructions.
WLAN Security Setting
Set an encryption key for an access point. This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
None Do not set an encryption key.
WEP Set an encryption key.
The encryption key can be entered on the next screen. The encryption key is displayed as a series of asterisks.
WPA-PSK / WPA2-PSK
Authentication Setting
These settings are available only on PS3™ systems sold in Korea and are available only on PS3™ systems that are equipped with the wireless LAN feature.
None Do not set authentication information.
EAP-MD5 Set authentication information when using public WLAN services.
Enter your user ID and password on the next screen. For details, refer to the information supplied by the public WLAN service provider.
Ethernet Operation Mode
Set the Ethernet data transfer rate and operation method. Usually select [Auto-Detect].
Auto-Detect Automatically set basic settings.
Manual Settings Manually adjust the Ethernet data transfer rate and operation method.
IP Address Setting
Set the method for obtaining an IP address when connecting to the Internet.
Automatic Use the IP address allocated by the DHCP server.
You can enter the DHCP server host name on the next screen.
Manual Set the IP address manually.
You can enter values for the IP address, subnet mask, default router and primary and secondary DNS on the next screen.
PPPoE Connect to the Internet using PPPoE.
You can enter your user ID and password on the next screen.
DNS Setting
Set the DNS server.
Automatic Automatically acquire the DNS server address.
Manual Manually enter the DNS server address.
MTU
Configure the MTU value used when transmitting data. Usually select [Automatic].
Automatic Automatically set the MTU value.
Manual Specify the maximum size of data packets (in bytes) that can be sent in one transmission.
Proxy Server
Set the proxy server to be used.
Do Not Use Do not use a proxy server.
Use Use a proxy server.
You can enter the proxy server address and port number on the next screen.
UPnP
Set to enable or disable UPnP (Universal Plug and Play).
Enable Enable UPnP.
Disable Disable UPnP.
Nov 09, 2008 | NetGear WGR614 Wireless Router
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Help connecting Cable Internet through D-Link DI-514 Router
what may be happening is the wireless pc as it was; needs the dns and ip address flushing, also the pc you connected the router to as you must have conflicting ip addreses Click start run then type ipconfig /flushdns. You should ensure that the router is set to enable DHCP to assign ip addreses and make sure your'e network cards on all pc's are set to obtain ip address automaticaly in the TCP/IP properties. Restart the pcs and type 192.168.0.1 in your web browser and get into your router setings and check in the DHCP section that all pc's have been given an ip address. If all fails you may need to reset the router
Sep 03, 2007 | D-Link DI 514 Wireless Router (DI-514)
Wpn 824 wireless issues.
if you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Jun 21, 2007 | NetGear RangeMax WPN824 Router
Sony Playstation 3 (PS3) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
