Question about E-Machines eMachines Desktop PC
I have an Evesham Axis Demon (Aug 06) AX1546000523-Kit; has it got wireless or ethernet on the computer? I need to connect to BT broadband Home Hub 2.0 which has wireless and Ethernet connections only. If not what sort of adapter should I get? Computer was purchased August 2006 Thank you
  • 1 more comment
  • av_troughton Oct 02, 2009
    Thank you for your help.
    Who's the "Old Hack" you or me?
    I have got a wireless setting in the control panel and a wizard to set it up. I've started the "set up" but haven't got the BT Hub yet, Wednesday I hope, then I'll see if the wireless works?
    The Evesham Axis Demon is Windows XP Media Centre Edition 2005, all over my head, but perhaps that may explain why such an old machine might have a wireless.
    If I can't connect with wireless I'll get an Ethernet cable, a long one!
    Thanks again;broadband at last I hope if it all works!
    Regards, av-troughton
  • av_troughton May 11, 2010
    Thank you for your help fixing the problem with my wireless connection. I have already replied to thank you, but apparently I abused you, I don't know how, if I did I'm sorry. I did jokingly ask "who was "Old Hack" you or me? Sorry if you took that seriously.
    Anyway just in case you did not get my answer to the computer problem; I think I have got a wireless connection, I found a wizard but could only set up a little as I haven't got the BT hub yet, that should come on Wednesday, then I'll know if the wireless connection works.
    Thanks again.
    Regards,
    av-troughton
  • For Old Hack May 11, 2010
    Look in your Network Connections control panel: Does it have the wireless setting? Can you use the Network connection wisard to set one up? Can you plug your PC into the router to turn on the Wireless? ( The Evasham Axis Demon, although it is a good machine, I dont think has wireless ) I, personally, would plug your computer into the hub with a Ethernet cable. Get one that is long enough.
  • 104 Answers
Should have an ethernet connection at rear beside the usb connections usually
Posted on Oct 02, 2009
Testimonial: "What does an ethernet connection look like?"
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
Computer won't recognise ethernet connection from router
I don't know the make. model, of laptop or your OS? Open network connections, is it enabled? Is there a Network Icon in the Tray Notification Area? You really do not need a Disk to connect. Just plug in the ethernet and boot the machine.The computer should ID the connection, if it enabled and working properly. If not open Device Manager , Network Adapters and enable the ethernet adapter.For further assistance respond to post.
Dec 18, 2012 | Computers & Internet
Trying to set up a LAN party for COD Black Ops - Zombies and some help is seemingly much needed. We have 2 TVs, 2 PS3s, 2 games, 4 players - splitscreen on each TV and a wireless internet connection...
First off I would not recommend wireless just because of issues with speed and latency.
You would need a 4 port hub and two rj45 ethernet shot gun runs from the hub to both of the units.
I would highly recommend this because of latency and other issues that might interrupt your lan party.
If you require internet access I would recommend getting a broadband linksys router www.linksys.com and following the steps above with your ethernet runs.
Let me know if you have any additional questions
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 06, 2011 | Sony Playstation 3 (PS3) Console
Hi, since having a new BT home hub, my inspiron 6400 will not connect wirelessly unless I do a 'repair' with it. Sometimes it detects broadband but wont connect wirelessly. My son changed the channel...
Most people have to just work out the configuration by them selves BT do offer a lot of support (0800 022 33 22) Their equipement is pretty good and widely used.
By the way the most least used channels are 1,6,and 11 there might be a default but these are the most complete channels which do not overlap(RE;
cnannel 1]--2.412 Centre frequency(ghz)
channel 6]--2,437
channel 11]-2.462
Mar 14, 2011 | Dell Inspiron 6400 Notebook
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
Need wireless connectivity for my Evesham Evolution HT computer
Go to search engine "Google etc" and type in wireless usb stick.
this is the easiest way to get a wireless connection on a PC.
The ram is another kettle of fish,,it has to be matched ,,so it is usually advisable to remove one chip and go to your local computer store and buy what you need, based on the example you provide.
Jan 29, 2009 | Samsung SD 608 (SD-608) Internal DVD Drive
Wireless connection problem
BT is right, the fault is at your end, because you can connect to the Internet with an ethernet cable.
You have lost your wireless connection with the wireless hub.
This could be low signal strength (especially if the wireless access point is in one part of the house and your laptop is in another room)
OR Your laptop wireless card has lost its wireless access configuration.
Check your laptop wireless configuration, check your signal strength, check your SSID, check your security (WEP or WAP),
Have you got MAC address filtering.
Go to control panel, click on network connections, right click on Wireless Network, Click on repair (might fix your connection problem), Else right click on Status (should give you indication of how your wireless is functioning or not functioning).
Check your TCP/IP settings is set for "Obtain an IP address automatically"
Without more information it is difficult to identify exactly what is wrong with your connection.
May 11, 2008 | Acer Aspire 5100 Notebook
Xbox360 connection
Yes, you are able to connect your 360 using a hardwired connection. In fact, it is even faster that way!
Your BT Home Hub has two ethernet jacks on it, for use with whatever devices you wish to connect to the internet (in this case, your 360). Simply plug your 360's ethernet cable into the jack, and voila! You can now access Live. However, if you wish to host games over live, you may need to open up certain ports for Live to use.
The ports are listed at: http://support.microsoft.com/kb/908874
A manual for using and setting up your BT Home Hub is at:
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=16536
Near the bottom of the page is a link for the PDF version of the manual.
Jan 01, 2008 | Video Game Consoles & Games
E-Machines eMachines Desktop PC Logo
114 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
