Question about ECHO, Inc. PB-251C Handheld Blower
Wants to turn off at full throttle - ECHO, Inc. PB-251C Handheld Blower
  • 1,040 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • Jim Parker
    Jim Parker Nov 30, 2009
    Did this solve the problem?
    Jim
My troy built riding mower won't run full throttle it only run at about half throttle
if it runs good at half throttle, it just wont throttle up it sounds like the throttle cable has slipped. you might try to adjust it to get full throttle back .but if when you turn it up to full throttle and it dies then you have a choke, carburetor, fuel line, fuel filter or fuel tank problem. hope this gives you an idea.
Mar 29, 2016 | Troy Garden
Rough idle, bogs when I give it throttle then dies
Brad:
Go back to the carburetor adjustment screws and snug them down gently. Do not use force on those screws or you'll damage the needle valve seats. Turn both screws out one and a quarter turns out and start the saw. The motor should stay running.... if not adjust the screws until it stays running. Turn one screw in until you hear the motor start to stall, then turn that screw out just a little bit. turn the other screw in until the saw starts to stall, then turn that screw out a little bit. Now if the saw bogs at full throttle, turn one screw out one quarter turn. See if the saw runs at full throttle... if not turn that same screw in to where it was and try the other screw the same way. If you're good, you can adjust the screw while the saw is running to get the best full throttle run. This is not an exact science, and it takes time and many adjustments to get the saw to idle and run at full throttle. Good luck... and have patience.
Oct 03, 2015 | Garden
When i flip switch to turn on it just starmts going full speed without touching throttle?
Sounds like the throttle is stuck in the full position. Can you adjust the throttle to other positions ? There should be a spring to return the throttle to a "off" position - and then you will have to twist to make it go. The spring may be missing.
Jun 15, 2014 | Razor E100 Electric Scooter
Adjusting the idle jets on a homelite super 2
'L' is the idle jet screw and 'H' is the full throttle screw. Make sure the air cleaner is not clogged. Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed up, but still 4 stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine keeps running. Hope this helps!
Jun 03, 2010 | Garden
It cuts out at full throttle.
Check the muffler and air cleaner for plugging. Try turning the H jet needle CCW about 1/2 to 3/4 turn which should make it 4-stroke at full throttle. Proper setting is for the engine to 4-stroke at full throttle, but immediately 2-stroke when cutting. (CW turning of H makes it leaner) See a Poulan servicing dealer for a rebuild kit. Be sure to check the fuel filter in the tank for plugging. Hope this helps!
Apr 07, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Tune a ryobi two stroke motor
Turn Both Air Mixture Screws In Until Seated. **DO NOT JAM SNUG ONLY** Turn Both Screws Out 1 1/2 Turns. Set the Throttle to Full Open and Start the Engine. Override the Throttle by Pushing the Governor Arm by Hand and Turn the High Air Mixture Screw(bottom of the bowl) In Until the Engine is Revving Properly. Now Slow Engine to Idle. Set the Low Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Now Set the Idle if Required.
Nov 09, 2009 | Electronics - Others
Does not run at full peak speed
needs the carb adjusted H screw needs to be turned counter clock 1/8th of a turn try that when it is running and the throttle full
Jul 22, 2009 | Garden
Once i Turn the throttle my goped turns off
it may be over fueling if you have turned the jet id sugest hold at full throttle and adjust jet whilst running it on full power
Jan 25, 2009 | Go Ped Know Ped Goped Push Scooter
ECHO, Inc. PB-251C Handheld Blower Logo
224 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
