Question about Refrigerators
GSH25JSRF SS Issue with water/ice delivery
My GE refrigerator no longer responds to the water/ice lever. It's as if the control lock is locked, but it is not. Filter replacement does nothing, and neither does turning off/on the ice machine.
Please help.
  • 3 more comments
  • pluey May 16, 2008
    Same problem. Ice maker works, but dispenser does not. Every now and then the water dispenser works. . . but is unpredictable. I guess I need the mother board? the refrigerater is 2 & 1/2 years old
    phughey615@aol.com
  • ggordo Jun 09, 2008
    I have exactly the same problem. Just like "oudie" in sol.2 I tested the crank and plunger and they are OK. I assume by now oudie and others have fixed the problem so what was the solution? Did they have to replace the controller board?
  • patsy44venem Jul 21, 2008
    Same problem but today the refrig. stopped completely. Two days to get a G.E. service person to our house.
  • Anonymous Aug 15, 2008
    I have a side-by-side Kenmore (whirpool) 21.8 cu.ft.purchased 6/2006.
    I am having the same problem, the Ice maker works but it is locked and it won' t let anything dispense. I have tried everything to get it out of the lock possition. Is there a part ? Any suggestions?
  • Anonymous Apr 12, 2009
    Same problem with no ice, except now water dispenser only works occasionally. Slamming the freezer door a few times will usually fix the water problem but still no ice. Now in addition to that the internal fan (and possibly compressor) is having a hrad time starting and clicks loudly for a minute or two whenever it tries to start up. RF is just hree years old.
  • 3 Answers
I had the same problem as do thousands of people with this same fridge. The mother board is bad and needs to be replaced. It is easy to do yourself and the part costs less than a service call.: Unplug the cord from the wall, remove the panel from the back of the fridge (it is about the size of a small shoe box lid) You will see the mother board (ice, water, light, and compressor control unit). It is an electronic circuit board. There are about 5 or so plugs going into the board. Remove the plugs and the retaining screws and search Ebay for the part#WR55x10552 GE Power Control Board. I found one for $74, popped it in, and everything works better than new!
Posted on Mar 21, 2009
Visit this website: http://applianceguru.com/forum1/13243.html I am having the same problem. A recall was issued and whether the fridge is in warranty or not, it will be fixed free of charge. This website lists all model numbers that are included in the recall and phone number to contact.
Posted on Jun 21, 2009
There's a recall on this issue - do some more googling and you will find it.
Posted on Aug 12, 2008
Same thing happened to me in the same week as you. I bought mine in July 2006 so it is just 6 months over the 1 year. it is still within the 5year but they said this part is not covered within that warranty. They said I would have to pay for a technician visit and the part. I already know that it is the controller board which I don't understand why that is not covered. that is the brain to the fridgerator. I know it isn't the the two parts that aren't responding (ice crank coil and magnet lever) cause I took those out and tested them and they work fine. Murphys law at work here.
Posted on Jan 12, 2008
  • Oudie Feb 28, 2014
    I ended calling for service, the guy came out and replaced no charge.
  • 833 Answers
Are you actually getting water into the fridge? Has the line frosted? You may have to defrost and make sure your freezer is not set lower than 5 degrees F.
Posted on Dec 21, 2007
Why is my GE Profile Refrigerator ice maker no longer dispensing ice?
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Model GSH25JSRF SS The fan in freezer clicking and working intermittley, the augor in the ice machine and the water dispensor are only working part of the time. You can hear a clicking sound as the fan...
On this particular model the fan and all operations are controlled by the main board on the back of your Refrigerator. This is part number wr55x10942. Less than $200.00 and not hard to change out.
Jan 31, 2010 | Refrigerators
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
RE: GE model #gsh25jsrf ss. The water does not dispense from door. Can I fix this? Thank you.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Oct 31, 2009 | GE GSH25JFR Side by Side Refrigerator
Water just keeps pouring out of the top of the ice despenser
I would say your water valve in the freezer is locked in the open postion or has broken.
Jun 07, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
1,407 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
