Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
Same monitor, same problem!!!
Monitor flashs power light for 5-10 mins before it will actually illuminate. Like an old fluorescent light with a bad "starter"...
While the unit is attempting to "come ready", disconnect and reconnect the 7 wire blue plug. Some how or another, this disrupts the start up pattern that is failing, and the monitor comes on as normal when reconnected???
Posted on Oct 02, 2009
I need to replace the fluorescent panel starter in my flat panel monitor
The problem is not with the Fluorescent Backlight of the Monitor, it's the Capacitor! Replace the Capacitor on the Power Circuit Board of the Monitor. The Capacitor will be slightly bulged! Use the same ratings of the dead Capacitor like it's Volts and Micro Farads. After adding the new Capacitors your Monitor works like new one. Enjoy!
Dec 27, 2012 | Computers & Internet
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Hello Experts, I have a HP Pavilion Tablet Laptop that won't boot. All keyboard lights and monitor lights (DVD controls) illuminate except the actual monitor, it does not come on and is completely...
I'm having the exact same problem on my less than 2 yr old HP Touchsmart tx2675 laptop. Could you please let me know if you have solved the problem?
Thanks and Regards,
Manish
Nov 01, 2010 | Computers & Internet
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
L1910B (Black) 19 in. Flat Panel LCD Monitor: I have a flashing monitor light and the monitor is...
Guest, If your Lucky Goldstar l1910B is 4-5 years old you will need to trade it for new or investigate the printed circuit board "switch-mode-power-supply/inverter supply to do repair on it. Depending on total "on" hours of use, may even need to refurbish with new cold-cathode-fluorescent-lamps" that provide "white-light" needed to see what is being displayed on screen. Just do some reading in my old fixya profile (louie12fix) for more info. After you do your research and have learned the flashlight test you will be able to make decision on what to do knowing all your options. You can type in the fixya nickname of most ccfl monitor tech's and read their profiles "budmrtn" "buddymc" "louie12fix" and mant more. Follow all links you find in the responses to "black" or Blank n Black screen ccfl lcd display problems. Good luck on the repair. 12fixlouie
May 03, 2010 | Computers & Internet
My monitor will not turn on, it was working fine yesterday and then I turned it off when I went to bed and when I woke up this morning, the power light is weakly flashing a dim yellow, but it wont turn on.
kmbass24, Could be "black screen of death" problem. The problem is inside the monitor! Most likely a power supply problem. If not handy with soldering iron, solder wick, removal/install of bad filter capacitors, and use of DVM then a tech will need to troubleshoot unit. Some units can be repaired for less than $12 in parts!!! It's the charge for labor that gets you in the end. $20 min per hr. Your monitor is no different than any other brand. Go to YOUTUBE and view some typical BSoD repair vids of "LCD monitor disassembly" LCD monitor repair" FYI and learn what the 2 common ROOT CAUSES of BSoD are. Hint for you is this: Have you seen the NEW style screw-in, curlie-Q, energy saving compact fluorescent LIGHT BULBS! Very similar technology is used to light-up your LCD panel to enable you to SEE what is on the display!
If this was of some interest, rate this response on fixya. bye for now.
12fixlouie
Nov 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
My monitor has no picture and a flashing orange light
koakes898, Here is a clue!! Have you seen the new style Curlie-Q compact fluorescent (CFL) screw-in light bulbs at the nearby Home Depot or Menards. Can you imagine them having long, thin, straight tubes and providing WHITE LIGHT on the opposite side of the screen of your FPD2275 display. If the "switch-mode-power-supply" detects a Fault in the cold-cathode-fluorescent-lamp" "electronic ballast" circuit Called an "INVERTER" it goes into SHUTDOWN mode to try and save itself from self destruction. Visit YOUTUBE and search out video clips (8-12 min run time) on "LCD disassembly" FYI !! I'll bet your monitor is in the top 2 types of power supply failure modes. Then you will Probably be able to decide on what to do with your monitor. Trade in for new, or BUY new and repair old to keep as spare. or try to do cash+ old swapout with Gateway for a same model-Refurbished. You do have a few options. Last option is attempt repair on your own if handy with soldering pencil and solderwick and solder. Lots of stuf on the web, you just need to do the search!! I'mlouie12fix on fixya. or lmistyrel @aol .com Hope this was helpful in some way. please rate this on fixya if this was of some use to you. Bye for now.
Oct 07, 2009 | Gateway FPD2275W LCD Monitor
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
Toshiba A200 Notebook Computer Screen Black Out
LCD monitor work based on backlight illumination, they have a fluorescent tube of high intensity usually located at the bottom ot top of the monitor sometimes they may even have two of these one on each side or on top and on the bottom of the screen, this tubes illuminate the screen from the side into the LCD device. The lights are powered by a high voltage switching power supply. A number of things may happen that can cause the symptons you are experiencing. You may have a bad high voltage power supply (locvated inside the laptop body or sometimes depending on the model inside the actual LCD lid.), you may also have a bad light tube or a bad flat cable that connects from the power supply to the LCD lid. Usually is not worth to pay for a repait like this as it is time consuming to dissasemble the whoel laptop to fix or replace any of the components involved in this. If you want a fast and cheaper solution, get a cheap LCD monitor and conenct it to the external RGB port of yoru laptop if you want to keep using it. Otherwise look for replacement parts online for the light tube, power supply assembly and cabling then get somebody to replace them for you.
Jun 02, 2009 | Toshiba Satellite A200-0ET00X Notebook
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
Sep 30, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
215 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
kj henriksen
kj henriksen
Matthew Spark
Matthew Spark
 Grubhead
Grubhead
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
