Question about Garmin iQue 3600 GPS Receiver
IQue 3600 won't respond properly to stylus. Responds if you touch one item down the lists. Example, to OK something, you have to touch right below the OK. It just recently started this, Maps display correctly and you can move the map with stylus or finger. Any ideas? Can you reload the firmware on this unit? Bill
I solved the problem by re-calibrating the screen. Go to the home icon on the screenn tap preferences, date and time, then tap digitizer. Then follow the prompts and tap exactly on the target Xs.
Thanks!
Posted on Oct 02, 2009
Garmin iQue M3. Gradually not responding to touch
First make sure the screen is clean of any dirt or oils that may deposit on your screen from your fingers. Use a stylist (a mini pencil like item that came with your GPS) or and other non metal semi pointed item and go through the screen alignment process. Hit the "X's" as you see them (it will move 4 or 5 times to ensure the screen is aligned.) After it is aligned it should give you other options. I have seen GPS's recycle trough the alignment process two or three times before cycling out. If you do this and you are still you are having issues, and you have tried resetting it, you may have a hardware issue.
Mar 07, 2011 | Garmin iQue M3 Pocket PC GPS Receiver
Won't turn off or on, wont do anything, is lit up though
Might try a warm reset. Unscrew the plastic top of the stylis. and push it into the reset hole in the back of the unit, remone it from the reset hole, then turn unit back on.
Mar 15, 2009 | Garmin iQue 3600 GPS Receiver
My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600
Even new, the battery is a 3600 sore spot.
If it has been left uncharged for two years, it is probably garbage.
I got a new and improved one for mine for about 30 bucks.
Try BraunOni, Eruope, I think, but the service was great.
May 04, 2008 | Garmin iQue 3600 GPS Receiver
IQue 3600 sim card problem
from Garmin:
Question: Why wont the PC recognise my the SD card in my iQue 3600?
--> Answer: Go to My computer and look for the following directory:
  • C: > Program Files > Palm > (user name) > file called 'sync'
  • Double click on this file and delete the four bottom rows that will look something like this:
"SlotId=0
MediaType=1935960423
DisplayName=SecureDigital (SD) Card
InstallDirName=Slot-SD"
  • Then try a HotSync as normal, it should then 'see' your SD card.
  • If all fails delete a second user name as sometimes this interferes.
Mar 14, 2008 | Garmin iQue 3600 GPS Receiver
My ique 3600 does not respond
Try resetting the unit and calibrate the screen. The problem is that the screen is not calibrated.
Nov 30, 2007 | Garmin iQue 3600 GPS Receiver
IQue 3600 missing disks
The simplest method is to update the software for the Mapping/Data, the one you probably had is sooo out of date!
http://www8.garmin.com/cartography/mapSource/citynav.jsp
City Navigator North America 2008 DVD
MapSource City Navigator North America
(includes access to the whole disk)
Garmin Part Number: 010-10474-00
U.S. List Price: $139.27 (for domestic US market only)
Sep 26, 2007 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Feb 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
