Question about Kenmore 23822 Top Load Washer
Washer is all over the place!
I recently replaced the clutch on my 23832 ( the retaining clip had come off and the clutch was riding all over the shaft. after replacing it with another good clutch off anaother machine, assembeled, it starts to go into the spin mode, and after about a minute or so it is so off balance it is pretty much dancing across the floor as mentioned by another user... the solution mentioned there was a support but i didnt touch any supports. is it possible the shaft is bent?
  • Chuck Gannon
    Chuck Gannon Oct 01, 2009
    the other ( donor machine ) has the same springs. how would i know if the springs are the problem? the other machine didnt vibrate out of control like this one...there appears to only be 3 main springs holding the bottom of the basket in place and 1 spring in the rear ( vertical ) both machines are identical is this what you are refering to when you say "shocks"?
  • Samuel Charles Spriggs May 11, 2010
    Not likely the shaft is bent -- that would require a good bit of force. I can't find the manual for this machine on the net. But it does sound a lot like bad/loose shocks.------------- Charlie
  • 5,911 Answers
If you've recently had the washer apart for maintenance, you probably have managed to unlevel the washer. The rear feet of Whirlpool manufactured top loaders are auto-leveling. You can usually tell if the washer if off level if the back appears to be sitting lower than the front. You can reset the level by following these very simple steps:
1. Make sure the wash tub is empty.
2. Open the washer lid and grab the rim of the wash tub opening (do not grab the tub).
3. Place one foot against the bottom front center of the washer.
4. Pull the washer towards you so that the back feet come off the floor. You should hear a clicking noise as the rear feet automatically level.
5. Lower the washer back in place and use a level to ensure the washer is level front to back and side to side.
This is a common issue when moving or doing maintenance on the washer. Many consumers do not know about the auto-leveling feature of these washers.
If you find that the washer is still unlevel after resettting the back feet, adjust the front feet by using a wrench to adjust the feet.
I would attempt these procedures first before assuming a bent shaft. I have never seen that occur. Its not to say that it can't, but its probably not common.
If you have any questions, or if you still need assistance, please let me know. I hope this helps you.
NOTE: Kenmore washers are manufactured by Whirlpool.
Posted on Oct 01, 2009
Testimonial: "still wobbles but you answered, so thats a plus."
  • Jeff Rockwell
    Jeff Rockwell Oct 01, 2009
    This model washer does not have shocks. The springs you mention are the drum suspension springs. Check to make sure all the springs are connected correctly. If there are adjustments that you can make on these springs, make sure they all are connected with the same tension. Otherwise, you may have a washer that id being pulled off balance by the springs. If the rear spring comes loose it will cause the drum to be off balance too. For an illustration of your washer, you can view it at searspartsdirect.com.
    NOTE: Another way you can tell if the washer is properly level is to place your hands at opposite corners (diagonally) of the washer and see if it rocks. Sometimes I have found the frame to be bent requiring a little more adjustment to get it level. In addition, watch the tub when it spins. The tub WILL wobble a little, but it should not be excessive.
How do you remove a throw out bearing on a 1997 harley
Step 1: Remove the magnetic drain plug with a wrench. (The drain plug is underneath the outer primary chain case on the left side of the motorcycle). Drain the fluid into a drain pan.
Step 2: Remove all of the screws on the clutch release cover with an Allen wrench. & also remove the clutch release cover. Discard the gasket that's located right on the inside of the clutch release cover.
Step 3: Loosen the clutch cable adjuster with a wrench to allow it to slack a bit in the clutch cable.
Step 4: Remove the retaining clip of the pushrod assembly with a pick tool. This should also release the two thrust washers located just behind the retaining clip.
Step 5: Remove the throw out bearing & Insert a new one into the same slot.
Step 6: Reinstall the two thrust washers and the retaining clip you previously removed.
Step 7: Tighten the clutch cable adjuster with a wrench.
Step 8: Replace the clutch release cover gasket and reinstall the cover by inserting and tightening the screws that you previously removed.
Aug 14, 2015 | Cars & Trucks
Tip
Replacing the Clutch on a Whirlpool Top Loader
This advice explains how to replace the clutch on a Whirlpool manufactured TOP LOADING direct-drive washer. This includes Kenmore, Estate & Roper washers. If in doubt, please post your MODEL NUMBER when submitting questions. This is a repair of MODERATE difficulty that can be accomplished easily if you follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in several ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
c. Some consoles have a series of screws located in the back. Simply loosen the screws to release the console.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Inspect both halves of the coupling for signs of wear. Replace if necessary (part #285753A).
10. Uninstall the motor mounting plate from the gearcase by removing the two bolts.
11. Remove the agitator by removing the center cap. Locate the center nut under the cap and loosen with a socket and ratchet. Lift both portions of the agitator straight up, exposing the gearcase center shaft. Remove the agitator clip and agitator washer from the shaft. NOTE: If there is a recessed square slot under the agitator cap, use a 3/8 inch to ½ inch socket adapter with extender to remove.
12. Now take the washer and lean it backwards so that you have full access to underside of the washer. Loosen the three bolts holding the gearcase in place. When you get the last bolt, loosen slowly as the gearcase will begin to drop from under the washer. Slide the entire gearcase and shaft out of the washer.
13. Remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip. Do not forget to retain the washer that is under the clutch.
14. Install the new clutch assembly on top of the gearcase. Insert the band (this looks like a metal hoop) and hold in place. Then, using a pair of needlenose pliers, place the end caps on the tension spring and compress to insert into the open end of the band. Release the tension on the spring and the band will stay in place. With the parts assembled, make sure you insert the retaining clip on top of the clutch.
15. Reinstall drive motor mounting plate on the gearcase and insert the gearcase into the basket drive tube with clutch assembly attached. Slide all the way up and hold in place. Seat the gearcase and insert one bolt and get it started to hold in place while you insert the remaining bolts. Tigthen all bolts evenly.
16. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
17. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
18. Reinstall electrical connector to the Drive Motor.
19. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
20. Re-install agitator washer and retaining clip on the gearcase drive shaft and then re-install agitator. NOTE: DO NOT over-tighten center nut. You can crack or break the agitator.
21. Re-install washer case. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
22. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
23. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
24. Reinstall console.
This may seem to be a rather lengthy process, but it is a simple repair if you follow the instructions step-by-step. Read through everything thoroughly before beginning any repairs. I hope this information is found to be helpful.
NOTE: Searspartsdirect.com, Pcappliancerepair.com and Appliancepartspros.com have helpful exploded view diagrams you can use to properly identfiy the parts you need, and to see how the parts are assembled.
on Mar 02, 2010 | Washing Machines
Tip
Replacing a Gearcase
This advice is for Kenmore, Estate & Whirlpool TOP LOADING DIRECT DRIVE type washing machines. Read the instructions thoroughly BEFORE attempting. This is a repair of MODERATE difficulty that can be accomplished easily if you follow the steps provided:
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
14. Inspect new gearcase assembly. Open the breather hole (covered by a dab of paint) using an awl or similar tool. Install washer on gearcase shaft and install clutch and brake assembly. Slide gearcase shaft up through the agitator shaft from under the washer. Hold in place and get one bolt started. Insert remaining bolts and tighten them all evenly.
15. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
(cont'd)
on Jun 23, 2008 | Kenmore 24032\24036 Top Load Washer
WASHING MACHINE
THIS symptom means but ONE thing. The drum clutch is burnt and slipping or said clutch is worn out. I just replaced the clutch and hub unit in my washer, original was burnt and slipping because of past overloading. The ole lady said "NOT ME, I NEVER OVERLOAD IT". Well, it works fine now. If yours is a Kenmore washer and drives right off the transmission, you have to remove the outer shell, remove the cap on agitator, then the 7/16 head bolt in the center that holds the agitator to the shaft, turn the unit on it's back, this after unhooking electric and hoses from back, then remove the pump by popping the clips off, remove the motor by removing the 2 screws in clips and popping the clips off and pull motor strait off, unhook the electric cable that powers the motor and pop same cable off the retainer that keeps it on the transmission, remove the 3 1/2 inch head bolts that hold the transmission to the standoffs, pull the transmission completely out of the washer and you'll see the clutch on the top around the shaft. under the concave washer, Remove the push-clip from shaft at clutch hub. Remove the spring clip that holds clutch to trans. Slide the clutch hub up and off the shaft. Place the NEW clutch hub on the trans and put it all back together. You'll find your washer works perfectly now. Plenty of spinning speed.
Aug 31, 2014 | Washing Machines
I have a stihl 036 in terrific shape and I want it to stay that way. I recently lost the e-clip that retains the rim sprocket. Is there a washer that is required? The rim sprocket with the new e-clip just...
yes there is a washer that goes behind the snap e clip go to your local small engine repair shop and get the right one e clip and washer or lown mower repair shop....
Jul 20, 2011 | Stihl Garden
Kenmore Top Load Washer. Original issue was it
16. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
17. Reinstall electrical connector to the Drive Motor.
18. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
19. Re-install agitator washer and retaining clip on the gearcase drive shaft and then re-install agitator. NOTE: DO NOT over-tighten center nut. You can crack or break the agitator.
20. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
21. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
22. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
23. Reinstall console.
It seems like a rather lengthy process, but it is a simple repair if you follow the instructions step-by-step. Read through everything thoroughly before beginning any repairs. I hope this information helpful.
NOTE: Under Line Item 10. - after you remove the motor mounting plate, make sure you disconnect the wiring harness from the the gearcase housing if it is mounted to it. Otherwise, you may damage the harness when you remove the gearcase assembly. Make sure you re-install the wiring harness in the fashion when repairs are completed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 14, 2010 | Kenmore 24032\24036 Top Load Washer
P0734 and P0761 codes related to 4th gear ratio and solenoid c shift problem
Its more than you think. 1. Inspect for a broken retaining clip by removing the valve body and then the valve body separator plate. Inspect the forward clutch control valve, spring, retaining clip, and valve body casting for damage (Figure 1).
2. If the clip is broken and the forward clutch control valve and/or valve body casting is damaged, replace the main control. The retaining clip has just been revised to prevent the chance of breakage. The revised Retaining Clip (F8DZ-7F194-AA) has circular cutouts on the side of the clip in place of the square cutouts on the previous design level clip (Figure 2).
3. Inspect the new main control (if required) before installing it and replace this retaining clip for the forward clutch control valve and spring if it's not the new design (Figure 2).
4. Any time service is required on any AX4N transaxle main control, inspect the retaining clip for the forward clutch control valve to be sure it is the latest design level, and replace the retaining clip if it is not. The revised clip is larger and will remain centered in the valve body casting groove. too repair estimate..400-800 dollars...Hope this help..Big shops will hurt yo pockets
Dec 16, 2009 | 1996 Ford Taurus
Transmission replacement
May 01, 2009 | Washing Machines
How to replace lid switch on Kenmore top loading washer, 23832
Just underneath the topcover approx. 2-4 inches from each outside edge there is a small clip. Push in on the clip one at a time while pulling up on the top. It will release.
Jan 10, 2009 | Washing Machines
Cannot remove clutch from gearcase
there is a spring clip under the washer and C clip slid screwdriver under it to remove it no clutch does not come with gearcase..clutch pt #285785
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 23822 Top Load Washer Logo
129 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
