Question about Bushnell Trail Sentry 11-9200 Digital Camera
My camera will not stay on once power button is pushed gives me hhhh then says off ????
Count down timer
Do a hard reset, turn camera off, take out battery's and sd card out. once you have everything out push your on/off button for about 5 sec. then put only battery's back it should say no card. Once it says that put sandisk sdhc nothing higher than a class 4 sd card, which is the speed of card not the size. If still not working call Moultire 8006533334 option 1 and 1 again for a live person to help you.
Dec 28, 2013 | Moultrie Feeders Lx30ir Game Spy Camera
I got my Bushnell Trail Sentry Digital Trail Camera and the code does not work so what is another code.
the first time the camera is used the code should be 0000 unless previously changed,try removing and reinstalling the batteries,this hould start your set up again.
press and release the power button and wait for 4 H's,"HHHH" to appear,this may give you another chance to use 0000 or whatever you chose as your password.press enter after each digit,then press enter again.the indicator should display PASS.if it displays ERRO then it is the wrong password.there is a password recovery service provided by Bushnell at 1-800-423-3537 and press option 2,you will need to provide your serial number to the representative.
hope this helps.
Jan 09, 2011 | Bushnell Trail Sentry 11-9200 Digital...
When reviewing pictures, by pushing the arrow, a screen comes up over the picture, detailing Camera, date, time, etc. How do I make it go away and STAY away? If I hit the Enter button, it will go away,...
You cannot make it STAY AWAY. THat buttn, the multi-selector switch, is useful. If while viewing your shots it is pressed to the right, then the shot info comes up. Push it once back to the left and that info goes away. If pushed left once again, you get a histogram of the phoro. Push it once to the right and that histogram will go away. without the histogram or information on the screen, you are in normal viewing mode and pressing that multi0selector switch up or down will cycle through your photos.
Oct 31, 2010 | Nikon D50 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Everything works....but hit shutter button & it goes dead.
Hold the power button in the ON position for 10 seconds, then release (obviously making sure the batteries are in first). This forces the camera to do a full reset - you will have to set the time etc when it restarts.
Hope this helps, it worked for me...
Nov 23, 2008 | HP Photosmart R707 Digital Camera
Fuji 6800
the solution......you should click the button only once.....then the picture will be taken only once.....if you press the button and keep it for some time it will take multiple pictures.....for taking a photo just click a button once......this will solve your problem.....if the problem still persists then the problem is in your camera.....that you can repair it by giving it in the company of the camera.....this will solve your problem 100%........
Sep 18, 2008 | Fuji FinePix 6800 Zoom Digital Camera
Password
cannot reset to the default password
Aug 08, 2008 | Bushnell 11-9000 Digital Camera
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Bushnell Trail Sentry 11-9200 Digital Camera Logo
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
