Question about Sharp AR-5316 Advanced Digital Imager Copier
When there is low voltage and the stablizer cannot power the copier, the error code 4H appears and copying cannot be done. what can be done about this? is there a code that can be used to correct this?
    New Friend:
    Problem Solver:
  • 7 Answers
To lessen the incident of displaying H4.. Use AVR or UPS..
Posted on Mar 04, 2013
  • Sharp Master
  • 1,297 Answers
Your problem in the fuser unit.Check and clean the heater lamp,thermistor or thermostat.
Posted on Oct 03, 2009
UPS does not supply power under 150~ volts
UPS will provide constant voltage out put.
The average working condition of UPS is 170 to 270 volt.
Below the level may not work.
Jul 20, 2012 | Computers & Internet
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
in order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
Aug 19, 2010 | Sharp AR-M160 Black and White Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp copier AR-5316 has the problem. Error code 4H appear and cannot copy.
Hello sir; You need to do a reset procedure as follow; Press "#", "interupt", "C", " interupt". then enter 14 press start, machine go back to normal.
Oct 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
ERROR CODE 4H ON AR-5316
There is a problem with the fuser unit ( exit where it gets hot), unfortunately you need to replace
either 1- thermofuse, 2- thermistor, 3- heater lamp
Sep 10, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
