Question about Maytag MGR6772 Gemini Gas Kitchen Range
Starts about 5 minutes after heating water..last
Hi, it starts about 10 minutes after heating water..clicking from all burners. Last night I just used the oven to heat something up and it started about 10 minutes later. Been going on for 3 weeks after I fried chicken. Thanks for helping me out..
    President:
  • 1,304 Answers
You may have oil and sludge collected on the ignitor tips, this sometimes causes loss of ground and they click
look at the one you cooked chicken on see if there is something there and clean it off
Posted on Oct 03, 2009
Testimonial: "Thanks for the help! Take care!"
How to fix gas burners
The electronics are controlled by AC using a simple plug usually. If you can locate the plug and reach it you may be successful resetting things by unplugging the cord, wait a minute or two and then plug cord back in. Try the burner controller again. If still doesn't work then controller module may need to be replaced.
Oct 14, 2014 | Dacor DR30DLP-H 30" Distinctive Dual Fuel...
How long does the model 81v52d last in years?
Did you clean sediment out of tank when replacing elements?
Did you replace thermostats? Thermostats go bad, or get out of calibration.
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Test elements.
Sounds like lower element is burned out.
Clean sediment out of tank. Check for water leak running hot water out of tank by putting ear against pipe.
Replace both thermostats.
Electric water heater will last 20+ years, IF ...
Electric water heater is totally unique because it can last forever with part replacement using parts from hardware store, as long as tank does not rust because of depleted anode rod, and pressure is kept below 80psi.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Annual water heater maintenance will pay you $10 a month, tax free money in pocket, by avoiding tank replacement.
Nov 25, 2012 | Water Heaters
Bryant plus 90 intermittent start-up
That's an intermittent problem. Could be: dirty filter, dirty blower wheel, dirty secondary heat exchanger, dirty evap. coil, weak or damaged high temp safety, loose wire connection, fault at control board, poor air flow. Just about 100 guesses! Could be's don't solve anything. Check for cleanliness. Clean flame sensor(flame rod that burner flame comes in contact with). These are the first I would try.
Mar 10, 2017 | Heating & Cooling
The microwave looks like it is working but no matter what I do there is no heat. I put in a cup of coffee and hit the minute button. It turned on and goes around but the coffee is cold. So I tried...
HELLO.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    I have a Omega HE100 ducted heating unit. It has stopped working last night. In fact, when I switch it on, the responsed instantly but the flame couldn't be lighted up and it stopped after 10 seconds,...
    Most of them are electronic systems I opened my he100 up and cleaned and adjusted the burners well used to take 10 resets before it would fire now fires up as soon as electronic ignition start every time total cost $0 and hour half work
    Aug 13, 2011 | Heating & Cooling
    Lost power last night - now Microwave won't work - control panel is not lit - unplugged for 10 seconds and replugged in - socket has power
    Hi, W/D here.
    Leave unplugged for a longer time, say 5 minutes. I have done this twice on my own, and it has worked, but it took about 5 minutes.
    --W/D--
    Feb 09, 2011 | Jenn-Air JMV8166BAS Microwave Oven
    When we are not at our cabin the temp is set to 57. Every time we go there and set it to 70 degrees the furnace will heat for 40-60 minutes and get to low 60's, then I notice hot air is not coming out of...
    It sounds more likely that your fan is not pushing enough air across the heat exchanger. If you have a multi-speed fan, I would suggest increasing the blower speed. Otherwise you will continue to cycle on and off on the high limit. Also make sure that you do not have any return or supply vents blocked off, as this often times will cause the same problem. Hope this helps.
    Nov 20, 2009 | Heating & Cooling
    Igniter "clicking" on its own...
    new spark module. Most stoves use a common part.
    Jul 25, 2008 | Tappan 24 in. Freestanding Gas Range...
    Ticking Sound of spark igniter persists
    Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
    Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
    Open Questions:
    Maytag MGR6772 Gemini Gas Kitchen Range Logo
    154 people viewed this question
    Top Maytag Kitchen Ranges Experts
    Lawrence Oravetz
    Joyce Nokleby
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
