Question about Toshiba 200 GB USB 2.0 PORTABLE EXTERNAL HARD DRIVE
Bus error pc=001186f0
How can I solve pc error 001186f0
Here is a link that might help. Good luck.
https://support.microsoft.com/en-us/kb/2622803
Sep 29, 2016 | Computers & Internet
How could I solve a pc error 001186fo
Make, model and OS of laptop please.
Sep 13, 2016 | Computers & Internet
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Al encender mi ACER Aspire 5100 suenan 2 pitidos y en la pantalla me pone: Sistem BIOS Version:V3.13 Bus:06, Device:01, Function:00 ERROR Resource Conflict - PCI in slot 03 Bus 06, Device:04, Function...
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Aug 16, 2010 | Computers & Internet
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
D:\ directory name invalid message
that error message is for the DATA BUS CABLE, you need to buy another DATA BUS CABLE, and verify the right connection contact in the Back of CD and the Main Board for this DATA BUS CABLE
Nov 26, 2008 | Compaq Presario 5000 PC Desktop
Toshiba 200 GB USB 2.0 PORTABLE EXTERNAL HARD DRIVE Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
